mine still work and my car was strictly complied :bunny: drive up against a wall about 2m away, put your lights on, roll the switch right to the top, give it a few seconds, then roll it to the bottom, youl see the beams move if they are still hooked up. the light heigh motors are NOT illegal, only when used in HID cars
just go buy yourself an HID kit. thats what i did, never looked back.
actually i did just try it and it worked. haha would've saved a lot of hassle the other night... ah well. :( it still needed adjusting anyway since it was already on the lowest height setting and was still pointing too high...
Also I read recently about the headlight adjustment on the dash - does this work? I always thought the motor for this was disconnected in compliance...I'd be thrilled if it worked. That'd be one awesome feature to have.
Haven't seen an example of the motor being disconnected.
The HID's have to be disconnected during compliance because they are not "self leveling". All HID equipped cars sold in Australia have self leveling lights... Not that you would know though.
and headlight cleaners....
Both are required for the Euro regs, and therefore ADR... Actually height adjustable headlamps, either manual or auto, are manditory for euro regs. Only exception is for cars with self leveling suspension like the Citroens.
Hi everybody,
I am having an issue with my M35 where my righthand headlight (low beam only) is not working. I have just changed the bulb only to have no success. On further probing, it seems that there is no voltage to the plug at all. I have checked all the fuses I can find (both next to the battery in the engine bay and in drivers side footwell and cannot find any duds. Trying to trace the wires through the engine bay I can across no fuses and eventually the loom disappeared into the passenger side of the firewall. I have also tried the ECU fault codes check on the CEL just in case, which reported no faults.
Has anybody else come across this problem or know of any other fuse box that I am missing?
Any assistance would be really appreciated thanks
Brendan
hi
did you have any success with your light, my M35 has exactly the same fault, i havent looked into fixing it yet
Try replacing the fuses with known working fuses just to confirm they are not duds (if you haven't tried this already). I had this issue on my s2. Couldn't see that the fuse was faulty but I replaced it and that fixed the problem.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
