Hey guys,
I bought this KKR560 Turbo. It was installed then taken to Gavin Woods.
He said it was overboosting because the wastegate was sticking.
I took it to Mr Turbo, who has bored out exhaust housing, enlarged wastegate, and now it looks like it should work perfectly.
Back to gavin, aparently the wastegate is still sticking half way, so it either overboosts or never hits boost, u can wiggle it and then goes back to working before sticking again.
I've looked at it, and wondering if the wastegate actuator is on too much of an angle to be able to work effectively? Can I bend the arm or bend the actuator mount?
Any feedback would be great :D
Thanks
https://www.sau.com.au/forums/topic/275837-actuator-troubles-check-my-pic/
hey mate i had same problems with kkr480 turbo
would stick and stay open and make hardly any boost.
only way to stop them over boosting or sticking is get the internal gate welded up and run 50mm external gate off the exhaust housing . which is what i done and now run between 7psi - 20psi... never had drama since..
its the only way 2 fix the cheap ass turbos.
Do you have any pics of your external gate install? I'd love to see them, you running screamer or back into exhaust? More pics the better, as I'm trying to weigh up my options and a bit of this would be DIY :D
EDIT: my email is studioibi AT gmail DOT com
Edited by islade
Yeh i can get you some pics this arvo.
if your switched on u can DIY, but u need to pull turbo off, housings off etc and be good at welding lol...
its vented at the moment but ive got a setup where i can plumb it back in by undoin 1 v band clamp.
there no need to get external to fix it your problem lies in the way the acutator sit as I to had this on my hypergear tr43i turbo since gthere similar in design do you see how your acator rod is not dead centre on the actour hole dats you problem modify your bracket so as it alligns dead centre dis will elimanate it getting stuck it is not hard 2 do aswell if you want more infromation i can give you more detail of how i modified mine.
Do I want more info?
HELL YES :D
Just throw me as much info as possible, I'll hopefully be able to do it tonight, and then if that doesn't work, I will have to explore these other options :(
If you want to Email me, my address is above, or post in this thread (in case somebody else has this problem in future)
Thanks, dude
Isaac
Hey guys, Just for reference...
OTOMOTO guy refering to 'bending actuator arm', but not saying what actually needs to be done
http://www.skylinesaustralia.com/forums/in...t&p=1987194
EXTERNAL GATED KKR
http://www.skylinesaustralia.com/forums/in...t&p=4249470
lowRB, the wastegate hole has already been made considerably bigger by Mr Turbo... not saying it's big enough, but that's not the issue i'm having at the moment.
I'd still love pictures of yours (unless that's yours i've linked to), as if it's done, it will be home job :D
Skyline01999, can't wait for the info, thanks again :(
HELL YES :D
Thanks, dude
Isaac
no worries well firstly ive marked out the exact problem on your photo.
you can see in the pic how it is touching the side of bracket now this is preventing it from going strgiht which causes it to stop sometimes halfway.
Now this is a picture of my one.
notice in mine how it is straight in the middle and also not touching anywhere now what I have done is firstly enlarged the centre hole that made it easier to put the rod in secondly cut down the line with a grinder where i have marked but leaving abit left at the top them dummi fitted it back and started bending the braket back until the actutor rod sits dead centre. now once uve found the posositon you can test it by pulling the acatuor rod a few times and seeing if it doesnt get stuck just make sure you have someone holding the bracket in postion so it doesnt bend back, now once you have the right posisiton using a small pience of metal to close the gap where u have bended the braket weld it all up in order it holds and you should not have any problems, but yeah if you test it by pulling it and it doesnt lock up then you can be prety sure it will work. hope this solves your problem like it solved mine.
Thanks skyline01999 I am going to do this tonight :P
Really simple question, how do i disconnect the actuator from the wastegate?
I can see the screw/thread in the middle, but i'd imagine if that was loosened, thread would still be screwed into the wastegate side rod? If that makes sense?
Also, I have an actuator from my stock RB25 turbo, if this didn't fix the problem, would it be worth trying that one on there, or get another actuator from somewhere?
Isaac
Isaac
no problem, to disconnect it there a circlip on the end of the actuator rod connected to the turbo as you can see the rod slides onto the hook on the turbo take the circlip off and pull the rod off it might be hard to take off since its not stright but just undo the bracket bolts and take the braket off first if its hard to come off. And the acutor from the stock one wont fit since the arm is made to size and has been bent and is also a 7 psi one which is to low for your application but ye if your problem is jamming there is nuthing wrong with your actutor its just the bracket so if you can get it stright there will be no dramas. good luck with it
Also when my flap got stuck open, mine wasnt from the rod being on an angle it was the flap inside, hitting the exhaust housing and gettin stuck.you need a fair bit of force to open the wastegate flap up i cant see it rubbing a tiny bit on the hole stopping it from closing sorry... i also drilled the hole out bigger like skline01999 did.. just to give it that lil bit of clearance but it didnt do anything 4 me.
the problem why it doesnt close isnt just the fact that the hole on the bracket is touching its da fact its not lined up stright on the hole in the acuator itself and also was that the wastegate hook on the turbo has some play on it and when its on a angle the hook when being pulled back so quickly it moves it and sometimes gets jammed if it is completly straight da rod in the centre of the actuor it doesnt force the hook to have to move so it doesnt jam. well thats what i found out after mucking around with it for a while
Edited by skline01999
Hey guys,
I just bent the actuator rod instead of moving the actuator bracket.
Hooked a compressor up, and ran it from 0 to 15 PSI and watched it open, the rod stayed in the middle (moving ever so slightly) for the full range of motion (getting nowhere near the sides of the actuator.
I've attached a pic, let me know what you think, i should find out tomorrow :P
If it's any help, i can upload a video of it slowly opening (air compressor power) if you guys think you can provide more feedback that way?
Thanks
Isaac
Hey guys,
Thanks
Isaac
alright so now does its still get jammed?
Just rang Gavin.
He said he disconnected the actuator from the wastegate, and played with the wastegate itself, and it was still sticking. So i think the bent actuator rod could definately help, but i probably need to take the turbo back in to get checked out, because there's nothing i could do if the wastegate itself is getting stuck :)
Just rang Gavin.
didnt think it would fix it, only because ive been there done that.. maybe its time to go external wastegate?
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
