  • Replies 714
Posted Images
lol i think you are misreading the cookies there Cara
they aint your typical tim tams lol
So if the car show is on saturday do we go up there on friday or sat morning ????
hang on
ohhhhhhhhhhhhhhhhhhhhhhhhhhhhh...........................this is a fmaily friendly site krishy :P
ill be going up to loxton most likely friday night after work.....i hope lol so u guys will have to sort out what you are gonna do whether you are gonna come up saturday morning or not, which will mean quite an early morning for you all.
hang on
krishys bringing tim tams laced with marijuana? COOL
in all srsness, ill probably go up on the fri night, last time i did 3 hours there and 3 hours back on the same day. i was munted by the time i got back
-D
wow... just proves again, SAU: biggest buzz killer on the net.
talk about no sense of humour :P
don't let the door hit you in the ass on the way out.
Insinuating that Cara is vommit material lacks a bit of tact on your behalf.....whilst on the subject though, have you had a good hard look at yourself in the mirror??
You're no oil painting pal but you'd probably look good in a skirt :P:D
Can we please keep this on topic i dont think we need to talk about drinking and Marijuana on this topic as this is a SAU-SA event and it is not in the best interests of the club . We need to be conscious of the image we are portraying to potential new members.
+1
Can I ask what are the options for accommodation?
Are we fending for ourselves? Our doing the groupie thing again?
I was thinking of:
Option A - driving up Friday night ... get a room ... go to show ... back to room for drinks ... drive back sunday
Option B - driving up Friday night ... get a room ... go to show ... drive back to Adelaide
Option C - driving up Sat early morning ... go to show ... stay the night ... drive back sunday
Thoughts?
people were clearly joking but ok
-D
I am cool with anything there Ruby
but would suggest driving up there on friday night....get a room....get smashed and then next day show and either stay the night or drive back either way i am happy.....its only a 3 hour drive so meh
and no Ben i aint bringing any laced tim tams lol
uh huh .. so its fine for u to insult members intentionally. yet when i was building up a joke, it gets deleted.. riiiight. feels more like china here every day.
here we go again with the double standards crap!!
I'm seriously over some of you guys, you keep dissing the place but can't seem to stay away!!
PULL YOUR HEAD IN STEVE and get over yourself, and as Shane said in above post, if this is indeed an SAU-SA event then keep on topic and keep your other crap for Wasteland!
Last verbal warning.
EDIT: Dan, Dohmar and others, post that shit elsewhere!
i come on sau coz i have friends on here and i enjoy discussions about cars, modding, events, etc. clearly i didnt see the conditional part of the contract when i joined SAU that said im not allowed to have an opinion.. my bad.
:O
:O
One more off topic post in here by you and you get a holiday........your post to Cara was taken as demeaning and as such it was deleted with nothing more said.
You on the other hand, chose to be smart and repost it which was met with a friendly NON official verbal warning.
That still didn't sink in so here we are now with you about to face my banstick!
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
