Hi
I have a mig,is it possible to weld alum?
If not what da ya suggest without purchasing a tig.
Thanks
I could be wrong...and quite often am, but it seems like a subtle ad
hmmm seems i was right...
...while im here the el cheapo gasless migs you can get from repco, supershite auto etc......im guessing it wouldnt be possible to weld aluminium with those...all this talk of gas has me a wee bit confused lol
you can get the alloy wire for those small units - and no doubt there are those disposable gas canisters in Argon also - but then you need a new liner for the wire feed ....
prob easier to buy one of those cheap AC TIG machines if you are going to try it.
cheers thanks chris :)
which do you think would be easier mig or tig...im a total newb at welding...was thinking of getting a mig cause i fail at arc welding somthing bad...but havent really had much practice in general
cheers thanks chris :D
Tig takes the longest to learn for sure, but it will give you a buzz when you lay your first perfect bead.
I dont stick weld very well at all, I have to guess what the filler is doing due to the slag hiding the weld.
I bought one of the chinese 200amp AC/DC tigs, similar to the ones on ebay. There is even one with a plasma cutter built in. Does the job nicely and easy enough to learn, just hit the Miller US website and practice, then practice some more. The gas can be expensive though.
My opinion is that mig is faster for batch work and tig is higher quality for custom work.
Bah, MMAW is easy, you just need to know where to look while welding. I watch the weld puddle at the end of the electrode, if you have the correct current settings for the material and electrode and maintain a nice short arc length. The rest takes care of itself!
    • Maybe it's time for a M3 F80 LCI, and leave it stock.  Drive it to a shop, sip on your latte with nutmeg whilst it gets serviced and on the way home swing by and grab some chai mix for the evening.
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
