  • Replies 57
It's called 'dosing' in the VL world, also know as 'flutters', but around here it's best described as 'compressor surge'.
It's the sound of the air bouncing off the turbine blades when the butterfly to the intake plenum is closed. Normally all this pressurised air get's released by the Blow Off Valve, but if you don't have one, it does that.
Different length, shape and designs of pipes make different noises...
https://www.sau.com.au/forums/topic/276031-stu-tu-tu/#findComment-4673870
It's either a HKS Super Sequential BOV or some cheap ass BOV or like what others have said compressor surge.
HKS Super Sequential BOV = Wank (Only useful on highly tuned cars that are running a lot of boost and the stock one cannot handle it any more)
Compressor Surge = Say goodbye to your turbo.
https://www.sau.com.au/forums/topic/276031-stu-tu-tu/#findComment-4673960
Is that the HKS SSQV BoV? I've been trying to convince a mate to buy one for his evo, but all the vids I've seen of it its a sharp, high pitched noise rather than the VL flutter.
Just curious, is "dosing" unique only to the VL, or is there a specific reason VL owners choose it?
https://www.sau.com.au/forums/topic/276031-stu-tu-tu/#findComment-4674172
Yeah either it's the HKS BOV or like others have said with the metal pipe.
Any turbo car can make the noise, it just depends on the BOV set up or whatever the owner does to it.
The stock BOV should not make any noise, at least no "Stu Tu Tu".
But if you put on an air pod, while still having your stock BOV, you will get a nice "Suction" noise then a "Choo" at the end (Only when on boost).
https://www.sau.com.au/forums/topic/276031-stu-tu-tu/#findComment-4674302
What the hell is that noise? I've heard it twice now, both times from VLs. Is it some tricked out BoV?
If you ask me I think it sound ridiculous. My girlfriend was in hysterics for about 10min as we drove beside this thing.
Thanks.
LOL! just search "VL turbo dose" on youtube,,theres thousands of videos on that stuff,,apparently they're a favourite with wog guys and their significant others
https://www.sau.com.au/forums/topic/276031-stu-tu-tu/#findComment-4674330
my ceffy doses like an athlete on the roids, but it comes from factory with no recirculation valve, and still runs stock boost on a stock turbo. all you have to do is take out the intake resonator and bolt in a pod and I get instant flutters.
GAGF if that's bad for the turbo, it came from factory like it and has run for 180,000 kms with no damage to the turbo or engine.
https://www.sau.com.au/forums/topic/276031-stu-tu-tu/#findComment-4674359
that is incorrect.
the only relation a BOV has to flutter/dosing is whther its blocked or not. the type of flutter/dose depends on the width, length and material of the induction pipe. the turbocharger does play a roll aswell.
all a bov does is hold the air trapped in the piping. so it bounces around and goes back through the turbo, for the turbo wheel fins to chop up and make a stuttered noise.
a SSQV HKS BOV has nothing to do with dosing....its just like any other BOV... but produces a whistle like sound when air goes through it. if you block it off, its the same as your OEM bov and every other blocked bov. does nothing special.
the Dose you hear on VLs sound like stupid dolphins or piegons as you heard.
they run a small metal pipe, no bov, and multiple bends to magnify thehigh pictched stuttered noise.
alot of the high powered veicles in japan and here automaticlly produce this sound as a side affect for high horsepower aplications but usally produce a much deeper tone due to larger turbos.
this is because piping is usally much larger due to larger turbocharges and dont run many bends.
although the title says HKS SSQV, its incorrect.
personally i hate the high pitched doses, which have been attached to wogs and VLs. but i am madly in love with the noise similar to the 650hp R34 GTR videoed above. would prefer it over a OEM "CHOO" or whistle anyday
my 2c
:P
https://www.sau.com.au/forums/topic/276031-stu-tu-tu/#findComment-4674583
the vl boys cut a gap in there intercooler piping to put there afm so that there is no restriction between pod and turbo.
using diffrent lengths and angles of piping gives diffrent pitch noises.
alot of the guys that i went drifting with on the track a while ago had it, sounds sick when your using your accelerator to control the slide.
https://www.sau.com.au/forums/topic/276031-stu-tu-tu/#findComment-4674589
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
