  • Replies 372
Posted Images
Maybe that was the intention all along :(
Damn it...my plan unravels
Toughen up you pussy ;) I'll wear shorts and a singlet ;)
Please find attahced. A representation of PC in his "racing" suit...No the other one is not Brad
Yeah but I'm sure it will turn shit later in the day haha
Can a mod please change mine & Daniels team name to "Team Yeah Mate" Cheers :huh:
Is the track the one on the left just as you've turned onto Wattle Rd??
Ill Change it.
Yes thats the track.
ITS NOT WANNEROO RACEWAY/BARBEGALLO
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
