I thought it may be helpful for some if I put up some pictures that show the easy way to identify a ceramic turbo over a steel wheeled variety. This may be helpful if buying used turbos or if you are unsure if your car has allready been fitted with steel wheel turbo(s). Pull off the front pipe and with an inspection mirror and a torch, and a bit of holding your tounge the right way, you will be able to see it.
Pic 1 - (above) This is a ceramic exhaust turbine - notice the double hex (12 point) end on the turbine.
Pic 2 - (above) This is a steel / inconel exhaust turbine - note the single hex (6 point) end on the turbine
Pic 3 - (above) Also a steel / inconel exhaust turbine - note the triangle end on the turbine
The above is true for Garrett Turbochargers as found on Nissan Skylines RB20, RB25 and RB26 - with the exception of the N1 GTR and Nismo Built cars, all R32, R33 and R34 skylines were fitted with ceramic turbo(s) from factory. Hope this post is helpful!
Edited by Antimatter
easier way is to see if a small magnet sticks to it than remembering those lol
Have you confirmed this works yourself? There was some talk that the alloy used for turbines is not magnetic, but i cant remember if it ever got confirmed or denied.
Inconel wheels dont attract a magnet. I assumed they would till I bought Nismo turbo's. When a magnet did not stick I sh#t myself thinking I had been ripped then I did some research. I can confirm the old turbos on my GTR did have 12 point head on the shaft and the Nismos had 6 point confirming this is a great guide...
Cheers
Lee
Confirmed - magnet trick does NOT work.
As someone else suggested - Inconel (the steel that turbine wheels are made of) is not magnetic. I.e. You will not be able to identify a turbine as steel with a magnet.
Can anyone confirm if the Garrett GT3037R is steel wheeled? I've been looking around for info on this for ages and cannot find my exact turbo on the net. Heres some pics of the turbo. Sorry i dont have any of the rear wheel.
  • 4 years later...
  • 1 year later...
Resurrecting an old thread, but is there anyway to identify the exhaust wheel while turbos fitted to the car?
I've tried using a mirror to see the id plate, but no luck, thought about a boroscope to put up the downpipe but I think the turbo elbos have to sharp a bend.
I don't really want to strip the turbos down, what with all thew work involved. All I can assume is the ceramic wheels are still there so don't want to increase boost.
Thanks in advance. :cheers:
  • 8 months later...
I, too, am going to resurrect an old thread. Same question as ms33, can you check for ceramic/steel exhaust wheel while turbos are mounted? And the photos above are no longer hosted, so if anyone has a picture depicting the 6 vs 12 points he's referring to, that'd be great. Thanks!
Umm....pics 1 and 3 work fine for me. if you can see them then the rest is self explanatory.
You're right. Just checked on my phone. Work computer must've been blocking the host site. Thanks. Cheers!
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
