  • Hey all, I have to clear out some room for the up coming projects so I have decided to part with some of the things that have
    accumulated in the work shop! The pics below are for your viewing pleasure,so if something catch's your eye feel free to
    PM me.The parts are from a 32GTR or a 33GTR V-SPEC. I am located in Adelaide, South Australia. I am willing to ship
    items so P&H will be at buyers expense!
    Cheers HULI
    2 x RB26 blocks (one has some grooves in bores from ring land failure and the other block is basically perfect)
    Slightly grooved block $200 (can be honed out)
    Perfect block (V-SPEC) item $600
    RB26 crank (larger oil pump drive snout) $400
    RB30 crank + girdle $80
    2 x RB26 girdle + crank scraper + oil pick up $150 each
    4WD GTR sump + gears + baffle plates (Off 33) $500
    V-SPEC turbo's (no shaft play and don't blow smoke) $800
    32GTR turbo's (no shaft play and don't blow smoke)
    R33 head (has cams, valves, shims, springs etc) $1000
    Fuel rail + regulator + injectors $350
    Fuel rail and reg only $80
    Throttle bodies + linkages $350
    Intake plenum $100
    Injector plate $400
    Pistons and rods (set of 6 but one has ring land failure) $150
    Cam gear backing plate $80
    Stock cam wheels $80 the pair
    2 x water pumps (stock) $30 each
    2 x AAC valve assembly $150 each
    CAS + CAS support bracket $250 (crank angle sensor)
    Coils (set or 6) + brackets $100
    Odd pipes,exh manifolds, elbows, O2 sensors,2 x y connecting pipes $5-$40
    2 x Oil and water lines $100 each set
    2 x oil cooler assembly $150 (one has magnetic Drift filter)
    3 x Harmonic balancer (2 from 32gtr and 1 from 33 Vspec) 32 ones $50
    33 one $100
    2 x Alternators $100 each
    2 x idle regulator valves $100 each
    Uncut wiring loom (complete from computer to battery) $450
    2 x power steering brackets $20 each
Cheer HULI
th_06282009184.jpgth_06282009188.jpgth_06272009141.jpgth_06282009182.jpgth_06282009179.jpgth_06282009178.jpgth_06282009175.jpgth_06282009173.jpgth_06092009126.jpgth_05302009088.jpgth_05302009089.jpgth_06282009152.jpgth_06282009154.jpgth_06282009155.jpgth_06282009156.jpgth_06282009157.jpgth_06282009158.jpgth_06282009159.jpgth_06282009160.jpgth_06282009161.jpgth_06282009163.jpgth_06282009162.jpgth_06282009164.jpgth_06282009166.jpgth_06282009167.jpgth_06282009169.jpgth_06282009170.jpgth_06282009172.jpg
https://www.sau.com.au/forums/topic/276870-rb26-engine-parts-sale/
  • Replies 41
Hey mate, willing to seperate pieces off the throttle bodies? need the top and bottom balancers/water channel pieces aswell as the vacuum bar
Cheers
Sorry mate, complete unit only! worthless to me otherwise!
POWER STEERING BRACKET ****SOLD****(igpmg)
is the price for both turbos?
Sorry Guys, the V-spec R33 GTR turbo's are $800 the pair
the R32 GTR turbo's are $500 the pair
the twin set-up for either R33 or R32! SORRY AGAIN!
R32 GTR HARMONIC BALANCER ****SOLD**** (sickr33)
Lots more great parts available! Send us a PM if interested in any of this stuff!! OR even call 0400262578 anytime!
Cheers HULI
PM's sent.
4 interested parties in the blocks!
harmonic balancer back up for grabs- 2x R32GTR and 1xR33GTR vspec.(no response from buyer)
alot of interest in loom also!
If you require any of the remaining parts, be quick!
Send me a PM if you require added pics or just want a question cleared up!
Turbo's come with everything from exhaust manifolds, dump pipes, O2 sensors, heat shields!
2 interested parties for injectors!
4 interested parties for both blocks!
Will not hold items anymore!
FIRST IN BEST DRESSED!!
Both power steering brackets ****SOLD*****
Merging intake pipe ****SOLD**** ONLY ONE REMAINING!
VSPEC Block ****SOLD**** (Junga)
R32 harmonic balancer ****SOLD**** (sickr33) ONLY ONE REMAINING!
Engine mounts ****SOLD**** (sickr33)
Crank main gear ****SOLD**** (sickr33)
VSPEC R33 harmonic balancer ****SOLD****
ALL OTHER PARTS STILL REMAIN! SEND US A PM IF YOU REQUIRE THESE PARTS!!
CHEERS HULI
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
