Hey Guys,
Im currently looking at purchasing some wheels for My M35 stagea.
Now I have done a little research on here regarding staggered wheels and 4wd systems. I have read that using staggered wheels on an ATTESSA 4wd system can cause problems.
Can anyone really confirm this?
Now this maybe me over simplifying things... but I cannot see how staggered sizes can cause a problem... after all the rolling diameter will still be the same. Its only the tyre widths that differ.
I am sure I have seen many heavily modified GTR's using staggered wheels and they also use the same ATTESA system as our stagea's... and correct me if im wrong but the Autech 260's use different offsets front and rear (I know its not the same as staggered wheels, but its effects couldnt be too dissimilar)
I would love to hear peoples thoughts and maybe some techno wizz's answers.
Ben.
I know nothing techno-wise but i've tired staggered wheels with same rolling diameter on the GTR and the system went bezerk. It would put torque on the front wheels when not needed and the car felt like it's tramlining. I also observed the torque split meter and it was going haywire.
I ran 18x8 225/40 and 18x9 255/35, Had surging issues on highway @ 100km/h.
Dont stagea's understeer? Mine does bad! Then why run smaller tyre on front?
Have you tried a heavier rear only sway bar?
Replacing the little 18x7.5'/hankooks with 18x9'/federal 595evo first.
Then I'll look into sway bars and suspension (GTR DMS coilovers)
try both swaybars, good tyres(RE001), make sure DMS valve the coilovers to suit the stagea, and trail brake or left foot brake and you'll be fine... I no longer have understeer issues, but you can drive around it...
to calculate rolling diameter i use http://www.miata.net/garage/tirecalc.html
Edited by RB_Ryan
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
