Hey guys.
Was just poking around in my boot and came across this unplugged cable. Not sure if it's standard or not - but where should it go? I have an outstanding 4WD circuit-related issue which I'm trying to figure out, and not sure if this may play a part.
Thanks for your help!
https://www.sau.com.au/forums/topic/277437-what-is-this-cable-for/
I have never seen that in a boot of a 32 before, looks aftermarket too me,you can see where it comes through from the cabin, factory runs dont normally go through there. have you tested it for power yet? has the car ever had a stereo or anything in it? also is there a fuse holder attached to the batter with the same cable going into it?
pull out the rear seats and try and follow it to where it goes :bunny:
Pulling out rear seats takes 2 seconds. Two u-latches holding down the base one on each side. Shove a long screwdrive and pull up until the seat base pops out. Then you got access to the screws holding the vertical part of the seat, undo the 2 scews, and slide the seat up towards the ceiling to get it off the hooks.
Then have a look around at where it goes :bunny:
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
