No. Look at these:
A) The sheer amount of rust and $$$ needed to fix up the body work.
From what you can see the outside of the quarters have rust on the bottom edge, underneath in the wheel arch, there is bound to be more.
B) The CAS, it has a LOT of build up on it which means it's been near the sea (hence rust)
That means it'll potentially have lots of electrical problems at some stages due to corroded connectors and stuff which might cost you a small fortune to find.
C) Km's doesnt really speak much for the condition. It's very poor for 130thou Km's
I've seen many cars that old come out very clean, so the km's maybe wound back.
aggggg!! not that one.. if that is the rust you CAN see, imagine how much rust underneath you CANT see! That thing will be attrotious rust bucket - not what you really want in a car that can do 250km/hr+. There are basic structural tests the car has to pass even if its 15 years old - that car probably wouldn't make it even onto the road.
And its been repainted, and by the looks of things not properly blasted back or treated before just slapping the paint over the top.
its good for parts, and that is about it.
The blurb says that it is not OK to register as is.
Why is it so?
My wife pointed out the wheels, and they appear to have only 4 studs?????????????
Could be a NA with an RB26 transplant and a nice "R" badge.
All in all. Does not look good but for parts only. It's rubbish.
El Bee & Humbla
Guest RedLineGTR
even if i had the money and time and lets say i was a spray painter etc..it would still be a bitch to cut all the rust out..there is alos rust in the engine bay...a car like that if not started regulary the engine would have alot of rust possibly on internals etc.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
