I live in Bangor man, if i see a black r34 matching that description i will pm you
Thanks mate, I've been all over looking in every carpark and scrapyard i can find, tried down Kembla Grange, Greenacre, Hurstville, Menai etc
My black R34 was roaming around from Earlwood > Kirrawee > Beverly Hills > Mortdale > Earlwood on Saturday, and no-one spotted me!
Then again, no-one took my car either T.G.
Oh well, I'm looking for 2 cars now. Someone on PA lost their car around there too (on Friday)!
A s15 Silvia white stolen from engadine on wednesday night about 1km from where R34 was stolen
details here
http://www.nissansilvia.com/forums/index.p...howtopic=395485
Looks like someone has a shopping list and hitting the engadine area
unfortunately I'd expect a few more to go before the end of the month.
I doub't we'll ever see those cars again.
Stolen from Out the front of my house in Yarrawarrah NSW (Near Engadine).
Smashed window and gone.
Completely unmodified car I can't believe why anyone would want it, other than just young hoons.
Has nissan factory aero bodykit, 2 door coupe stock rear wing Black nismo carbon pillar garnishes and eyelids.
Number plate black on white XLR 85U.
If anyone has seen this car aywhere please contact police immediately.
Please help I'm devestated.
Damn thats terrible. I had 2 abo kids ruin my drivers door lock with a screw driver trying to get into my Er34 sedan. Some of us have the worse luck
hey man maybe you should post up the vin and engine number too incase they try selling it off without the plates or something.
might make it a bit easier to find ??
Edited by 32NSMO
details here
dammit, i'm at the gf's over the weekends in menai, car stays down there on the street every week, ive done so for the last year and a half ive had my car, nothing so far but i'm still paranoid about someone taking it even though its alarmed, immobilised, club locked religiously. plus comprehensive insurance, but i just dont want anyone to wreck it or take it coz of the work ive put into it so far....
i feel for your loss but really as its been said on this forum a million times, if you cant afford to put comprehensive insurance on a skyline, go for something cheaper, not worth not having comp insurance as you and others have figured out.
Hope it still comes back to you in one piece and hope financially you can recover if the worst case plays out
I'll keep a look out down my way also
down near parra area,
I have nightmares about my car being stolen, wake up sweating !!!
went crazy at my gf once cus i thought i lost it in the car park, its a horrible feeling
good luck mate ill look out for ya
Saved ur number into my phone
if i see even the plates on a different R34 ill buzz ya
  • 5 months later...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
