First of all I was saying. If I start my car an put it in drive an slide it cross to tiptronic mode it would show 3rd gear but I have even move the car yet. I though it would suppose to be in 1st gear while stationary without moving the car. I need some direct injectors. Any body possible know where I could find it for the vq25dd v35 250gt skyline 2003. I have one leak direct injecting cause my car to run rich
Honestly, I don't know why, but you don't seem to be interested in listening to the advice you've been given in this forum. You're obviously well out of your depth. Your lack of gratitude for those that have helped, and inability to string a legible sentence together doesn't help.
Good luck. You're going to need a lot of it.
I have tried every diagnostic advice from many of you which cause ms spend alot of money. Seems that none of the advice is working. Yall have access to these cars, parts and other items that can assisted yall with ur car problems. These vq25dd are not familiar to were am live an for every advice I get possible it makes me spend money an nothing works. All am asking is a website that sell injectors for these cause because there is one cylinder that making the spark plug have a dry foul on it an that cylinder smell like fuel
Were I live everything GA a be order an shipped here. Parts are not available for these vq25dd an yall advice made me spend more money an these people who diagnosis the car stating no codes at all. About this one cylinder that causing a rich running engine misfire. It just one cylinder which I meet a bit of fuel left inside so I was suspecting leaking fuel injector.
So it's all our fault then? Where do you live? You haven't told us, and I didn't see anything in your profile.
I think you've been advised to get your injectors tested multiple times, but I don't think you've taken this advice. Unless you do, I'll bet this will end up in tears.
Edited by Spong
But this is a DD engine.. so an injector that isn't closing fully isn't just going to have a 'run rich' issues like a non-direct injected engine.. you are going to end up with combustion pressures forcing their way through the leaking injector, back into the fuel rail and causing major issues overall, not just a fouled spark plug and poor economy.
I live in the Bahamas. I change alot of plugs an everytime I change it. I get a misfire an its the same cylinder that causing it. An not it is the coils causing it
Why aren't the coils causing it?
Edited by Ben C34
It only shows the highest gear you are allowing your gearbox to reach. The actual gear is not related to the display
They brand new Nissan coils from Nissan Japan. OEM
So?
Have you tried swapping coils to see if the problem cylinder moves?
Who says your wiring is all good?
I would be checking that before messing with the injectors. But it's your call. Up until now this site has wasted your money.
Edited by Ben C34
Everything yall saying I have test. I have already swap coils an plugs an problem still exist. I meet a little bit of fuel in that cylinder that causing the misfire. Then other five dry. Time to swap injectors to see if the problem persist in another cylinder
You can order a minimum of five, and still be cheaper than factory.
Your looking at 330AUD each for genuine ones...
They might not be of the same quality however.
Up to you to take the choice.
What plugs are you running, obviously not the correct quad earth's, they are impossible to find.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
