guys as I briefly mentioned in a thread I'm considering a workshop run to sydney.
I'm looking for EOI as of now.
I'll be in a Reveseby workshop for 3 days only. if you book the car will be dropped, left there,job done, then picked up once I'm done.
I have a cost I have to meet for this to happen and if I do not meet it then its a no go.
currently its set for the first week in August (MLB is later in Aug.) as that is the earliest I can pull this off.
ok who wants work done?
(don't reply if you are not going to commit. - questions welcomed of course.)
Edited by Chris Rogers
I'll commit to a reverse camera with S-Video out, if you can wire it to power on when i go into reverse? (no drilling)
I'd appreciate it, still contemplating that alarm we discussed. I really want to keep my stock OEM key entry.
Also somewhat interested in the HITV tuner you have on the site, does that use the cars built-in antenna?
Edited by g33k
im interested on that chris. i will need to know how much it will costs me first tho even just the estimated $ and the dates you are here. I need a run down or more like a check up on my alarm wiring through the BCM (kinda worried about water dripping in). also i just need my doorstep lighst working! so basically more electrical side of things. very interested on the reverse camera aswell.
Very keen but cant 100% committ till a couple of weeks.. whens the latest you need to know by chris
25th is the cutoff. I need to book everything arouund there.
can do the camera easily enough. wont have s video though. (none do.) alarm via OEM key - yep! TVuner- no oringinal antenna - hidden items. PM for pricing. (yours will pave the way for everyone else btw.)
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
