http://onyxsyndicate.com/newman/e30gtr/e30gtr_88.html
I spent a few hours last night buttoning up the AN Plumbing on the car. DETAILS DETAILS DETAILS!
Oil feed and cooling lines:
The coolant line attaches to a nipple on the water outlet. Instead of going through the hassle of welding on an AN bung, I simply used a hose end cover. It's a little corny, but it looks pretty good.
Ran the lines to the Aeromotive FPR. I still need to put a plug in the other port. I also cut off the vac port for the old charcoal canister and plugged it, then added another clamp for the fuel feed line at the back of the plenum. You can see what's missing if you compare it to THIS pic.
Another shot of the FPR
I wish you could see the brackets that I made for the brake booster line. I made 3 stainless L brackets and used them to mount line clamps to. They came out really nice and hold the vacuum line very straight. I am planning on mounting the check valve in between the two closest to the camera. Again I used hose finishers to clean up the look.
Another shot of the FPR showing the cable clamps holding the return line.
Another shot of the brake booster vacuum line. There's a clamp that's hard to see mounted to the head lifting bolts. (The other two are off the plenum and intake studs)
Shot of the drain and coolant line. I made both the drain flange and the block flange, wish I had a pic of them off the car, they came out awesome. I still have to do something with this coolant line.
Here's a shot of the block flange on the car.
I also took the rotor hats off the car so I can get them anodized.
  • Replies 74
Posted Images
The level of detail gets better as the build goes on, well done :)
Only thing I can think of is maybe some flame proof wrap for the turbo oil and water lines, it will get damn hot in there and wouldnt want them melting
Amazing! Im sure you will as it seems you miss nothing. But im assuming your going to clamp that hose on the right away somewhere? Itl rub through in a matter of weeks sitting on that seam in the bodywork! (Pic of lines under Turbo compressor by the "M24" casting)
Yeah, that's why I said:
"I still have to do something with this coolant line."
In the pic's caption.
I'll probably butterfly it to the drain line and glue some vacuum tubing to the seam.
  • 3 weeks later...
Shot of the intercooler and radiator installed (temporarily):
Then I started installing the window gaskets and some of the trim. The trim is actually blacked out with vinyl, which is a pretty popular way to do it. It looks really good:
Lastly, I made and installed some AN lines to be used with my PCV vacuum setup. That unaatached line will go to a catch can, then into the exhaust evacuator.
Got my coolant pipes coated in brushed aluminum PC and my bumper brackets in black.
I put a bead on the pipes with these vice grips I modified. Got the idea from Dan (JUICEDZ4)... In fact that's actually his pic... but mine are nearly identical.
Check out his AWESOME cavalier build here. I know it's a Cavalier, but check it out, it's unreal.
I bought some cheap summit racing window cranks and machined an adapter to run them on my gutter power window housings.
More shots of the outside. It's even more yellow than it appears in photos. Very odd color indeed. 4/6 windows are in. As is BLACKED OUT TRIM
PHAT AZZ... (the apron has some black on it at a weird angle so it looks crooked, but it all gets covered by the rear valence) Also got the trunk latch and tails installed. Looks like a fox notch hahah.
A shot of the CHROME BILLET WINDOW CRANK$$$ installed (23 bucks from summit)
And FINALLY got a set of these. SOOOO much better than a crescent wrench with electrical tape on it.
Also summit racing must hate that I keep adding shit to this order over and over. Check out all those different ship dates, all on 11.95 handling. :D
Nah, they probably love me...
Look at all this other shit I ordered.
Added a line clamp for the oil feed line and installed the EGT fitting into the manifold. The schedule 10 should be thick enough to not weld a bung on there, time will tell.
Powdercoated coolant pipes installed, you can also see where I am going to weld the BOV flange on.
Steph's baffled catch can installed. You can kinda see how the lines route now. One more line comes from the bottom of the catch can to the exhaust scavenger, which will be after the WG return and flex section.
A shot of the line feeding the catch can and also notice the brake booster check valve installed in-line. Again, trying to keep it ultra clean looking, this time line mounts to firewall.
Rear PACKAGE TRAY dyed black and installed. Instead of factory mounting I simply chose to use 2 stainless self-tapping screws in the front and clips in the back.
Lastly for tonight: Back Glass.
Just scooped up this, and the interface to communicate directly with AEM:
http://www.race-technology.com/dash2_2_31.html
And a fuel sender from summit. (Oh yeah and a 2.75 cent fitting that's backordered until october, LOL)
First thing I did was install the fuel tank level sending unit. Pretty straightforward.
Radiator fan installed:
Wideband bung welded on:
Spiffy downpipe bracing to motor:
Lastly, and most awesomely, I made this closeoff out of laser cut aluminum and pre-preg carbon fiber.
Large work was conducted above a machine, turbine very good! Successes in future!
To many on Rb26 liked to put here such turbines!
1000hp!!!!
HKS
This is probably the best comment I have ever received in any of my build threads.
Edited by ctnewman
glad I'm not the only one with tape on my crescents haha
So when do we get to see the flares?
flares, even the rears can't go on til sideskirts are on
sideskirts can't go in til fenders go on
fenders won't go on til it's tunning, probably, so you gotta wait a bit...
Wow....I thought an E36 with an 1JZ would be crazy, but this Bimmer made me speechless. Really good and detailed job mate. Quiet cool to see that you left the steering wheel on the left side :ninja: It's really going to be a trackday monster.
Good luck in the future :P
  • 1 month later...
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
