Hey im assuming this is fairly normal granted its been pretty cold?? Drips a bit of water too. It all stops once its warm?
Just dont remember my old clubsport doing it quite as much...
If it stops when warm its nothing to worry about! Mine does the same when cold.:D
https://www.sau.com.au/forums/topic/278906-r33-gts25t/#findComment-4711510
+1 to the mentioned above.....my car blows a heap of smoke when cold start and as soon as it warms up a bit then its all sweet......just try not to drive it when its really cold lol
nothing to worry about mate
https://www.sau.com.au/forums/topic/278906-r33-gts25t/#findComment-4711527
don't warm up your car in the morning. bad for your engine. wears your plugs, allows unburnt fuel to condense and drip down past your rings into your oil diluting it.
more relative to what you're talking about, if you warm it up for like three to ten minutes it will take MUCH longer to get rid of the water vapour. Doesn't hurt your engine... it's what it's designed to do. Warming up for 5 minutes is an old wives tale. or husbands. either way, it's lame and misguided.
best way to warm up your car in the morning and get rid of the water vapour is to nanna it until it reaches just under operating temperature (a safe temp is about 70-75°, suitable op temp being between 80° and 95°C).
Try it out, the lot of you. If there's one thing you can trust, it's a dude on the internet. (That dude is Doctor Karl, bitches.)
Edited by Dorigecko
https://www.sau.com.au/forums/topic/278906-r33-gts25t/#findComment-4712933
:D
https://www.sau.com.au/forums/topic/278906-r33-gts25t/#findComment-4713035
while it is a bit off topic, i am also against the letting your car sit there and idle to warm up. the main reasons being that it takes longer for a car to warm up when it's just sitting there idling, which means the car is running for longer at colder temps. the other reason being that it doesn't warm up the oil in the gearbox or diff.
another thing to take into consideration is that if you run your car for 10 mins every morning before you start driving, over a 1yr period, that is nearly 61 hours of running that your engine has done that hasn't been taken into account on your odometer, which means more than likely not taken into account on your servicing frequency. and not to mention the extra fuel you are using.
https://www.sau.com.au/forums/topic/278906-r33-gts25t/#findComment-4713470
30-60secs then I drive it. Stagea (being auto) I cruise along at 1500rpm while people behind me hurl abuse. Skyline I shifted at around 1000rpm (3L ftw :blink:) till it was out of cold start (>65deg).
Just don't load it up.
Edited by bubba
https://www.sau.com.au/forums/topic/278906-r33-gts25t/#findComment-4715420
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
