  • Replies 180
I dont think you are.......I think you are ken quadrangle
am I right? :rofl:
yeah yeah...go on..mock me....its saturday night and my jokes suck balls!
Im pulling out too - golf tomorrow
yeah yeah...im aging gracefully
Yes your jokes are bad AND you where plad, nothing gracefull about that.
lol
Typical eMsta :rofl: Bitching out at the last minute :)
haha nah man - i wasnt sure in the first instance. Sundays are usually golf days - playing 18 holes tomz
I think im addicted to the game man!
Are you coming to the initial meet point Kez?
Nah. I'll meet you guys between Mt Eliza and Mornington. I'll just be pulled over on the side of the HWY so keep an eye out for a yellow Supra and hit the horn when you see me.
drivin a jazz and playin golf. i suppose your senior citizen card's in the mail?
Also my car may be a little dirty, was only meant to go out for dinner and was going to wash the car after that but i have had 1 or 6 toomany so i will see how i feel in the morning.
Well it's strictly imports only but it's your first meet so bring him along. At least its a nice turbo car and people will appreciate it :)
Heading to bed now. Will need to get up at 8ish to wash my car and get ready.
See everyone in the morning! :P
Edited by jezza boii
car washed. camera and cb charged, stocked up on mother. cy'all in the morning
I just got home again going to bed soon, have not washed the car, dont need a camera, forgot to organize a cb and will get red bull on the way.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
