Last weekend i decided to change the fluid on the 32 to see if it solved my 3rd > 4th crunching issue..
Filled the box up with some castrol VMX80 as recommended, took it out for a spin and ended up smelling gearbox fluid. Returned home and pulled the shifter assembly off and found the shifter boot was cracked - has now been replaced.
However the box still seems to be leaking after changing the fluid, the bottom of the car is covered in oil. Going to have a look this weekend but thought i'd get some ideas on where i should be looking.
Also - what is the fluid capacity for a GTS4 gearbox?
Hopefully i've just overfilled it or something!
https://www.sau.com.au/forums/topic/279040-r32-gts4-gearbox/
oops.
you need to drain both the box and transfer case now because you just put 4l of oil into the transfer case. also depending if you drained the gearbox last time you may have no oil in there now either. If so don't drive it until you fix it you will stuff the gearbox within about 50k
2l of auto trans fluid through the shifter for the xfer case.
4l of gear oil for the gearbox through the filler on the side of the gearbox.
Does the transfer case have a drain plug like the gearbox does?
I recall seeing something similar to the drain on the box on the back side of the transfer case where the front driveshaft goes in - is that where you fill it? Or should i just fill through the shifter..
Edited by endless
yep both the gearbox and xfer case have both a drain and a filler.
you can use the shifter to fill the xfer case if you want and it is more convenient, but it is also possible to overfill it so be careful
Thanks for the help guys..
Drained transfer case on weekend and refilled, also took the drain off the gearbox to see if any fluid was left in there and luckily there still was about half a liter in there as when i originally drained the box it was only jacked up on one side.
Stoked as my 3rd to 4th crunching is almost completely gone! :(
Only crunches if it's hard shifted to 4th above 5.5k RPM, may try some Redline LW shockproof down the track.
  • 1 year later...
just a quick questions, didn't want to start another thread since this is similar,
does a r33 gts-4 gearbox take the same amount of fluid? got a gallon (3.785 L), of redline shockproof lightweight oil and just want to know if whether thats enough or not before I start changing the fluid.
Thanks!
Edited by OoskylineoO
Thanks!
have the car sitting level and fill it up until it starts to dribble out the filler hole, then lock it up. i'm pretty certain your gearbox will take 4L just like everyone else with an rb25 or rb26 box. i had 4 quarts (1 gallon - same quantity you have) of redline lightweight and after tipping it all in, the oil level was only just shy of the filler hole by about 1mm. you can get away with that quite comfortably, unless you wanna be really anal about it and go buy another quart and only use a tiny dribble out of it to top it up.
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
