  • Replies 73
Keiran and Brendan - have put down your needs for rooms.
Will be speaking to the owners 2moz after work to try and organise more rooms - will let you know ASAP.
Liz - you wanna share with Juliette?? Will make life easier for both of you :P
Hey Bec: My booking is for Kate and I not just me, just confirming you have us both down.
Are we still cool for just the Saturday night? How are we swinging that as far as room/pay etc.
Cheers
Chances would be high Pat, I spoke to them a couple of days ago and there were 2 extra rooms, but Id have to call them to double check.
Im not calling twice though, so confirm - if there is a free room, do you want me to book it just for Friday night??
Let me know and Ill make the call for ya :happy:
Hi,
yeah im 100% certain i'll need a room with 2 single beds on friday only.
If you could book/reserve a room for me that would be great.
Thanks
Let me know and Ill make the call for ya :thumbsup:
Thats right - everyone on the list in the first post has a room booked under their name.
Pay when we get up there.
Thanks!
I had no idea you were organising it all. Really appreciate it.
Kieran.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
