Hello,
I have a 1998 Skyline R34 and need a spare key cut. I've been to kiosks in shopping centres, then locksmiths. But as yet no-one can copy the key. The last locksmith I tried told me I need to call Nissan Motor Co. and buy the blank key from them, then take it to the locksmith to get cut.
Is this correct?
Anyone else done this, or had it done another way?
Thanks.
https://www.sau.com.au/forums/topic/279386-skyline-r34-key-cutting/
That was how I had to do it for my 02 34 ......Key from nissan mo. then to locksmith for the coding etc....... Not a cheap exercise the GTR Key alone from Nissan was over $100 from memory.
But still better than not having a spare key
Hello,
Is this correct?
Thanks.
Given the year im gonna guess its a transponder key - no theyre not cheap. No most locksmiths dont keep any transponders other than late model falcon compatibles.
My GTR key is just metal so it wasnt an issue - came with two spares anyway so i havent had to. (I used to work reception for a locksmith company here in ballarat)
can i see a picture of the key?
Chalk and cheese but i had to order a pre-cut key for my N16 pulsar while i was still working there, bought it cost price, still 100 dollars. Yes, for a PULSAR XD
basically it needs to be programmed to your ECU as well if this is the case, and all this does add up in terms of $$$.
They dont have a transponder in them unless some had it as an option as i was with my mate when he got his 98 GTT spare key cut just at the local locksmiths at the shopping centre. The guy there thought the same thing and checked it twice for the transponder but nothing. I havn't got a spare cut for mine yet but i dont think it should be a problem as long as they have the right blank key.
Generally first glance will tell you with most Nissan keys. and AU falcons...not always, granted, bc my other key isnt like this.
As below:
I've got a '98 R34 and it doesn't have any electronics in the key (except for central locking button). Took it to my local locksmith and he cut it for me. No coding needed.
Ditto, I just used the Mister Minit at my local shopping centre.
As below:
Yeh true its like Commodore keys in the VT's etc have a metal bit that sticks out a little that earths around they key on a metal strip. It isnt uncommen they break either leaving you stranded trust me :banana:
Thats correct. The car wont turn on unless its thouching that bit.
The earth also provides a small amount of charge to the battery in the commodore keyhead also which prolongs the battery life for longer.
Its still one of the easier cars to break into though.
Thanks so far!
Given the inconsistency with all your experiences , it seems its the random skill of the operator when copying the blank. But, none of the shops in Doncaster Shoppingtown could do it as they didn't carry the black (not think enough). API in Heidelberg cut one, but it did not turn in the barrel.
The blank does not need to activate the central locking as I have an aftermarket security system, so I'm just looking for the basic key.
@ b3za - what's the name of the locksmiths you used?
@ - ss07 - what's the name of the locksmiths you used?
Michael.
That's usually true. Have you seen the process most places use to cut keys? A 5-year old could do it on the automatic machine and it would take only 5 seconds. If the person does it quickly and sloppily so that the teeth don't perfectly match, a lot of times it doesn't fit into the lock, or even worse, gets stuck in the lock, as happened to me before :P
Its a bit more complicated than that, having done it myself in my last job.
It LOOKS easy...but sometimes, it really isnt. The guys i used to work for had something like 20 years experience and still struggled with some keys.
It may be harder than it looks or I give credit for, but it really shouldn't require that much experience/dexterity. We are talking about the same machine right? The one where you secure the original and a blank key on a cutting device, and you move it so that it follows the grooves of the original key while it cuts the same grooves on the new key.
The pimply teenager behind the counter at the key-cutting place near Target in Chinatown certainly didn't look like he had any decent skills/experience when he cut my key.... :)
Thanks so far!
Michael.
im going there tomorrow mate so ill get the name/number of place if you like and will PM ya
The pimply teenager behind the counter at the key-cutting place near Target in Chinatown certainly didn't look like he had any decent skills/experience when he cut my key.... :(
that machine relies on each key to be lined up correctly, and depends on the speed and smoothness of flow of each operator to work correctly.
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
