Originally posted by red900ss
heh, I did that once....B-Man is still wondering which way I went. :P
:lol:
I dont think we will see skylines in australia for a few years yet. When they do come out they are gonna be pricey too. Lets just hope they do eventually, but if they dont I am not too worried. As long as the import laws behave.
hehe i was expecting "nissan to lauch skyline into space" or sumfin.
So we'll be gettin wat seems to be the nissan equivalent of the LanEvo8 (or as I prefer to call it the 7.5 coz its not much different to the 7). Also is it gonna be called Nissan or Infinty as we don't have an infinty brand in australia, do we?
heh, I did that once....B-Man is still wondering which way I went. ;)
And you had the air con on - and Doc was with you too !
Yes, Yes, you chopped B-Man. But never again - Now I have the auto Gloria - it's a drag racing machine !
OK, back on Topic - IF Nissan was to sell the R35 GTR, how much do you reckon it would be ??? >$100K ????
i'd expect sumfin that's about 20k more expensive than a top of the range 350z. Altho if they're bringing out a GTR, they'll have a GTt and a GT variant... fo the ppl that can't afford a top of the range car.
OK, if, in 4 years they are less than $150K and I am working for a company that does a novated lease / salary sacrifice and I am still not married then I will 'think' about getting one.
Until then - The GTS-t and Gloria will have to do me ! ;)
meh, once I hit 30 I'm buyin myself an R34 front 350RS Stagea Stationwagon. Fun to transport family in and you have an RB26DETT with a 5" turbo back exhaust to push you along... mmm
Hang on a minute, I thought Nissan separated the Skyline from the GTR as far as the name was concerned. Have they changed their minds again or have the news sites got it wrong?
Either way Nissan Australia importing the GTR isn't good for anyone other than Nissan. It will just mean higher priced cars holding their value for longer, which is bad news for enthusiasts.
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
