Removal & Replacement Of Heater Core Skyline - The Right Way, Without Removing The Dash At All
ok so did the bypass on the weekend which worked a treat until we can afford to do the full job...except now whenever i drive it once i turn the car off heaps of coolant comes out of the overflow bit in the coolant bottle. is this related to the bypass in any way? or do you know why it would be happening? everything else seems to be fine...
^ at a guess - the principle is the same. you'd just need to make sure the insides are the same as the write up i guess, have a look behind your glove box to see if it matches the OP's tutorial
kel*bel - could be, just keep an eye on your coolant levels to make sure your not loosing any, if it runs fine i wouldnt stress about it too much
looks like im gonna be trying this out on the gf's 31 soon, its been going for a while and finally started leaving big pools in the footwell
i've had a look and it looks pretty similar to what you described, will report back with the findings
Hay mate just did the today using you tutorial saved me so much time! Anyway i would like to know what did all you guys do to get all the coolant out of your carpet and car? did you get it detailed or pull the carpet up and clean it? was just curious as to how everyone went about it?
you could get it detailed - might as well get your whole car done as well to make it worth while. or hire a wet/dry vac and do it yourself
dont know how well those these work but you could try moisture packs (you know the powder stuff in a container that is meant to suck up the moisture from carpets if you leave the lid off). once again, prob not good enough to completely get rid of it all but worth a shot i guess
Thanks Jason, you just saved me alot of money. Changed the heater core on my R34 25GT, all up it only cost me $200 - $50 for heater core and $150 for de-gas/re-gas and service the air con.
I phoned Nissan and they wanted $500+ for a new heater core - crazy. Much cheaper buying 2nd hand lol
Hope this heater core last I really dont want to have to do this again :D
  • 5 months later...
Awesome guide took me about 2 and 1/2 hours (that's not including a re-gas) the hardest part was those dickie screws on the plastic pipes.
I got quoted about $700-800 + parts for the job to be done (dash removal way) so about $980ish
This job has costed me so far
$180 for brand new heater core
$40 for De-gas
$130 for Re-Gas (when done)
Total - $350
I'm very interested to know if anyone has achieved this on an r32. I've got a 4 door gtst which the heater core needs replacing and I'd really not spend the $1000 in labour to remove the entire dashboard. I find it hard to believe the dash has to be entirely removed in order to access the heating core.
  • 2 months later...
Thanks to your guide i saved atleast $500..did it myself and you just feel good after fixin it knowing that you did it in one day not like the mechanics..they freakin take time so they can charge more..i got quoted $800 for it :ermm:'
$280 for the heater core..brand new
$40 for the regas
$100 for the regas
Thanks mate top job!
<quote>
Step eight: So now that you have the upper and lower plastic pipes removed from your firewall, you will now be able to remove the heater core element from the heater box. BUT FIRST...There is a plastic clip running across the element holding the element it in place, you can do one of two things here: snap it off in frustration or take your time and try prying it off slowly. I cracked the shits and just snapped it off – you don't need it anyway, all it does is hold the element in place during manufacture, that's what I think anyway! The aluminium heater core element will happily slide out of the heater box and you will be holding it in your hands.
</quote>
There is actually one small screw on this plastic bit holding it in place. Its on the top side of the plastic bit on the right hand side.
  • 3 weeks later...
Wow what a time and cost saver. I read the instructions about ten times thinking that it couldn't be that easy...... But it was.! Took me about an hour and a half Thankyou very much!
  • 4 weeks later...
$40 for De-gas
Total - $350
Rob where did you purchase a new heater core from? I'm after a R33 S2 one myself.
Yeah I'm dealing with it as well, though I'm taking a slightly different approach. I've still have the AC connected, and have managed to get the heater core out. It took more work obviously, but since I have more time than $$ at the moment, it was worth it for me. I had to gut the inside of the car to get the carpet out anyway, so have taken the whole dash apart and took the heater box out. I see on the heather core where there is some white corrosion stuff, or calcification, so I imagine that's where it was leaking. Not sure if it can be fixed, or if it's even worth fixing $$ wise.
Still hoping brat81/rob will reply back as to where he got his new core for $180 from.
  • 6 months later...
Great write up. I've got a problem with water bubbling sounds in the dash, but there are no leaks.The bubbling sound comes on when taking off from being stationary and goes away after a few secs, my mechanic said its most likely the heater core. Would this procedure fix the problem?
ETA The car is a r34 gt-t sedan
Edited by skizza r34gtt
This method is the absolute bomb. :worship:
It took me less than 2 hours to do this job. The most inconvenient part is taking the car to get degassed and then regassed.
Saved bucket loads of cash that are better spent on say a bigger turbo or a power fc. lol
Trickiest part was definitely screwing the plastic pipes back on the heater core while upside down under the dash LOL Those little screws are a pain. :rant: Highly recommend a strong magnetised screwdriver for that job. :-D
  • 2 months later...
I think my heater core is gone... I get the smell of hot coolant when i turn my heater on and constantly getting steam coming up on the inside of my windshield.
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
