Hey guys.. couldnt find the tech help section.. so i figured this would be the best spot.. kinda..
I have an R34 GTT, recently i thought my water pump had died on me as i was getting no water flow through the top radiator hose, the top hose would be hot, the bottom hose would be cold.
So i took out the thermostat all together and tried again.. yet again no water flow.. so i got a hose stuck it in the bottom hose, water comes out the top no problem, vica versa still OK.
Swapped the water pump + thermostat on the weekend to an Rb30 item + Nismo thermostat, while at it i swapped my rad hoses to Silicon items aswell.. (mate told me my factory water pump still looked OK, it only had the slightest play in it, blades all ok)
Now by no means am I a mechanic, so i could be missing the most BASIC thing in the world. I've filled it up.. and yet again it seems like no flow. I idle the car for about 10 minutes and you can feel the pressure building in the hoses (as normal.. kinda..) and then the rad cap opens up to let the boiling water out of the overflow hose.. obviously at this point i turn the car off and let it cool down..
PLEEEEASE help me.. so confused and have no idea or reason i can think of as to why its overheating SO easily.
Also, if anyone knows, does ALL the water from the engine HAVE to pass through the turbo water lines, mine look abit small (Apexi turbo swap) and if it has to all go through the turbo i think that could POSSIBLY be the issue..
Edited by illusiVe
Sounds like the Radiator is blocked. Actually, it seems obvious. If you have changed everything bar the radiator and its still doing it...
PS Nismo thermostat is only causing you more harm than good.
radiator seems to hold pressure no problems.. its only when the car is getting damn hot im getting steam outta the overflow hose.. at which point i know its too hot..
if it is the radiator it'd have to be a DAMN tiny hole.. cause i dont see any steam ever coming out of it itself, nor water
i can get water through the radiator no problems with just pouring water in the top pipe, it comes straight out the bottom pipe of the radiator.. imho it also wouldnt explain why i dont get water coming out of my top radiator hose =(
ill still doublecheck + swap the radiator tonite.
Edited by illusiVe
It's not going to be the turbo water lines.
Now what temp are you getting on the cluster? Is it actually moving off half way and towards hot? You might still have a bad radiator. Just because you put water in the top and it comes out the bottom doesn't indicate it's good unfortunately, the core can be flowing poorly and water will still flow out OK. Have you been running coolant in it?
I would remove the radiator and take it to a radiator place to be check and cleaned. Failing that you may need to look at a possible head gasket problem, of which the symtoms can be found on here by searching.
Get the rad properly checked out first but, re-fit it then move on from there.
thanks james.
yeh the temp cluster moves up towards high.. but in my 3 years of owning it until this issue happen'd i had never seen it go past half way. I have always ran coolant in the system, however since the issue im just throwing water in until i can fix these stupid gremlins.
Can you just throw me a basic reason/s as to why it could be headgasket related?.. just cant make sense from it.
after talking to a mate, apparently RB's have a bleed valve somewhere near the intake mani? (plz confirm) which u need to open to get all the air out...
i have no idea where this is or what it looks like (i know what an intake manifold is though!) if anyone knows or can pics me.. would be HUUUUUUGEly appreciated.
  • 4 months later...
old thread but issue continues..
ill check for the second one tomorrow.. going to start from scratch
1)clean out engine water lines, thermostat+housing,waterpump+rad
2)redo thermostat + waterpump, wait for goop to sealup
3)bolt shit back together
4)fill rad with fresh coolant.
5)bleed system + test
anything else i may be missing?
  • 4 weeks later...
mate i got the exact same problem.
tried all the stuff you have....
i just keep a close eye on the temperature and if if gets too hot when im in traffic i just give it some revs to get the water flowing...
pretty lame but im to lazy to figure it out lol
  • 1 month later...
had a water leak at the back of the block, having it fixed and new lines made up.
battery check yours =)
remember stock gauge doesnt go up until its PASSED a safe temperature for awhile..
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
