cheers ay, What other goodies u got?
If you need any more weight saving, let me know mate.
I have plenty of other dry carbon parts for the R32 ^_^
It would be good to see this beast rip down the quarter mile again.
Hi Guys here is a few pics of whats been going on the last few days, made up custom 4" titanium dump pipe into twin 4" side exhaust and 2" screamer into 4" tip to make it look like the others. ALL OUT OF TITANIUM looks amazing!!!!
also -20 Braided radiator hosing getting done today and most of the -10 fuel lines are done.
554870_10200928910612124_1238680233_n.jp
544394_10200928909932107_1547654801_n.jp
429649_10200928908332067_1405390738_n.jp
734023_10200928907612049_1965016353_n.jp
374551_10200921591269145_1943060114_n.jp
Car is looking great. I wish I could find a supplier for the titanium when I did my exhaust.
Will be great to see what it can do after the weight loss.
Shoot me a pm later on if you need to loose more weight but pretty much anything you can think of ^__^
  • 1 month later...
It gives me great pleasure to announce that we are the New World Record holder for Fastest H-pattern Street Tyred GTR on the planet.
We decided to head to Benaraby Dragway for the weekend for Round 3 of the CQDRA Championship to give the GTR a run. This is its first run since blowing the gearbox up at last years Jamboree in Sept. Now I really wanna give the guys and gals and Benaraby Raceway a huge wrap for the awesome event they held and the support they gave our car was unbelievable. The track condition was perfect, best I have seen if not better than Willowbank. They are doing a terrific job out there spending a lot a dollars to get that place up to spec. Great Job keep up the good work. ;)
Before I go into too much detail. I got to give our Main Man Mr Mark Jacobsen from Godzilla Motorsport a huge thank you, for all he has done for us, his support and knowledge has been unbelievable without his over the phone support last night this would never have been possible without him. Proud to part of the Godzilla Motorsport Team. Secondly another huge thank you to Dave Sheehy at CPV Tuning, for his continual help for the team, his valuable knowledge and input helped us immensely.
Ok to the runs, we not only broke Theo Woollett's previous World record 8.95sec @ 159 Mph which has stood for over 6yrs put we managed to back I up 4 times in a row, completely smashing it out of the ball park.
1st pass - 8.91 sec @ 152Mph with a 1.33 sec 60ft
2nd pass - 8.65 sec @ 150Mph with a 1.23 sec 60ft
3rd pass - 8.59 sec @ 152Mph with a 1.27 sec 60ft
4th pass - 8.52 sec @ 162mph with a 1.30 sec 60ft
Car is running the following combo:
Tyres - Mickey Thompson E/T Street Radials 275/45 R17's all round
Gearbox - Full PPG Billet 5 Speed Dogbox (Same as Theo's)
Engine- Was running Approx 1100 + HP at Flywheel
Fuel - E85 Sucrogen
Here is the pic of the golden ticket
923221_10151549364763485_1046025106_n.jp
Here is a quick vid of the 8.59 run will post more vids soon:
Hi Guys,
Went to Benaraby with our new setup and run some very very quick times, This GTR is now the Fastest H pattern GTR in the world on Radial Tyres with a time of 8.52secs at 162MPH, we broke the record 4 times with the other runs being 8.91, 8.65, 8.59 and 8.52. The car done some very impressive 60 foot times as low as 1.23, 1.27 and 1.30 on the final run. Big Thanks to Mark Jacobson from Godzilla Motorsport for advice and tunning over the phone last night. Definitely the smartest man when it comes to RB engines. Here is a video of my 8.59 getting very loose haha
:wub:
thanks mate, even with twin chutes I was standing on the carbon brakes that hard they all started glowing bright orange. One of the officials thought my car was on fire hahaha na just the brake rotors mate!!!
Congrats mate. Really great to see the new result. Well done Matt!
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
