  • Replies 129
Posted Images
If you had to remove the engine and all the other engine bay stuff probably a good week to do it all properly, i already had my engine out, so it only took a couple of days.
Hi Guys
Have finally collected all the tooling i need to pull apart my gearbox, have found the problem with it, there were 2 crunchy bearings on the mainshaft making all that noise, so all in all a fairly cheap fix. Was gonna replace all the synchros and bulk rings and all the other little bearing but have found out nissan no long make spare parts for the FS5R30A Gearbox anymore so that was a real kick in the nuts. So i just be replacing the 2 bearings and slapping her back together.
Also just ordered a ship load of braid and fittings as i am re-doing my fuel system so i can run on e85 and also sent my turbo housing, manifolds and dumps away to be ceramic coated. I bought another set of cam covers and still tossing up the idea of getting them chromed or anodized, hopefully my newly painted engine bay will look better than every before.
Cheers
Benny
Yeah Cal gonna buy it by pallet 4x205Lt Drums, my r33 will only run e85 for power runs and drag strip, don't plan on using it for street use. But the R32 will most probably running on e85 all the time.
Ah wish the shed was another 3 bays bigger got to much shit in there, i'm hurrying don't worry should hopefully have my turbos and manifold back on monday then the engine is going back in not long now thumbsup.gif have to catch up with some time robi !!!
Finally got my turbo housings and manifolds back now its time to get this ball rolling and put the engine back in. Still waiting on a few more fittings and have ordered a Billion Power Steering tank and Got a set of Bride Floor Mats coming as well.
185654_10150110643518485_679318484_6368555_6328750_n.jpg\
  • 1 month later...
Hi Guys
Another update, got the engine in the car today, all went well. Still waiting on a few more parts to come in the mail and have to order the Vipec V44 yet but all in good time. Gonna send my other Cam covers away to Hi Octane next week to get powder coated (still don't no what colour to get yet). Should have my new Hankook tyres tomorrow, and hopefully here back about my new car i am getting. I have put a deposit down on a 2008 Mitsubishi Evo X MR a nice Black one as the white ones seem to be to expensive still, will hopefully have it all sorted out tomorrow as well. Anyways here's some pictures of todays progress:
Super Jealous
Hey Ben, whered you get the bearing kit for your gearbox? I've heard CBC Bearings sell a kit. Need to replace the bearings in mine I'm pretty sure, when I have a daily I will be pulling the box out and doing that. Will give me time to see if everything else is all good and order parts (if they are available) if I have to replace anything.
Back on your car but, engine bay respray looks good, its suprising how much of an improvement it makes especially on darker cars. My old Calais got much nicer with some paint in the engine bay
Back before I could afford a Skyline :P
Edited by 89CAL
Yeah Cal i got the bearings from the bearing shop across the road from bob jane tmart's in Victoria St i think it was United Bearings Cost about $30 each, you will need a lot of gear to pull the gearbox apart cost me about $1200 in tools just to do the job as you need puller kits and hydraulic press for putting the bearings on. As for the engine bay, the paint job makes it look 100% better than before should look fairly nice once complete, deleting all the ABS shit makes a whole lot better aswell.
We have a press at home, and dad has plenty of bearing pullers etc at his work so hopefully should be right, He seems to think hes got the gear to do it so should be alright lol
$30 each is alright, did you replace all of them? It seems I have at least one worn bearings on one of the shafts (has a nasty clunk in 5th gear and makes some noises when releasing the clutch in neutral) Thinking about getting a lightweight flywheel while the gearbox is out but not 100% sure on that yet
Anyway, enought thread stealing. Will talk about this further in the Mackay thread if you have any more information about what you found with the bearings and what you ended up having to replace.
Back to NUR33 :) haha
Change of plans again... still have some ideas floating around in my head but i'm leaning towards turning the R33 into a full and proper time attack car now as i have no need to have 2 street cars, as the Evo X will be here in a couple of weeks. So everything will pretty much be getting sold and starting from scratch. If anyone is interested in any parts give me a yell, i'm in the process of writing out a list of parts that have to go.
send me a copy of the list please :thumbsup: .
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
