  • Replies 340
Posted Images
It will all be new stuff, Im just hoping I can fit the w2a cooler in the engine bay lol
Cool, ill give you a hoy If i need a hand :rofl2:
Drop the motor as far as possible, run an over the motor plenum again, and sit a custom W2A cooler on top of the motor, particularly towards the back of the motor...
no you dont, its cold down here.
hahah at the rate this project is going Ill be living back on the gold coast before its finished lol
Thats an idea, although, I have an angle grinder that hasnt been used in a while, and I hear it calling to me lol
Saw a w2a cooler on a big power 2j, gave me an idea on where to mount mine, Im going to try and get it under the plenum, with a 180 deg pipe coming off and into the thottle body, Will have to do some measuring on the weekend.
Also the dirty 30 short motor should be assembled on Sunday.
Then its time to find another 25 head to use, that way I will have 2 mostly complete motors, might even buy a standard or small aftermarket turbo and put on the 25 and tuck it away in the corner for a rainy day.
Will get pics of the new engine on Sunday.
For those that havent gotten bored with my very very slow project.
Damn Bills :P
Also while im thinking of it.
Who has cut the radiator support panel to allow for easy engine and g/box removal and refitting? I cant see it being a stressed part of the chassis and it would mean It would be much easier to swap the motor and box out being that last time i did it i bent the rad support getting the rear of the box over it.
Weve done it to our race car. Our radiator sits out in front more cause of its size. We just made up an ally plate to goes back over and bolts down eachside, so its removable.
So go for it! Cut the bitch out!
Well my hands are cut to shreds but the intake manifold is off the rb25 now lol.
Few questions for those that can spare the time to answer them,
#1 Can I ditch the coolant rail that bolts under the plenum, only reason I can see if being there for is the factory oil warmer, or is that the only path the coolant can take on its way back to the radiator?
#2 After looking at the rats nest of a loom in the engine bay I decided I will re-wire the whole car, not sure on how good of a job I will do, but at least all the seperate systems will be seperate and will help with any diagnosis. Does anyone have some pointers on what wiring to use, I was thinking multi-core trailer wire, but will it suffice? Also the Altenator? I cant see how it runs back to the battery due to 3000000000 other seperate looms running with the cable....All the under dash wiring will come out as im not going to use the factory dash, and will just have basic intruments (RPM, Boost, Oil Pres and temp and water temp)
#3 Has anyone undone the 2 grub screws on the intake side of the head, what is behind them? Im hoping its the coolant galleries as I want to use them to run some braided line into a header tank/swirl pot thingo, to make sure there is never any air in the Head.
#4 What else can I ditch being that this car is track only, none of the heater hoses are going back on the new motor....nor will I run a speedo
#5 Being that the Microtech has no knock function, should i leave the knock sensors out, or should I put them in and run the wires to a plug that in the future I can use for a knock box...I think its a good idea but im a newb at these full on race cars.
Hope you guys can help...as I want the neatest solution possible.
Thanks
Andrew, I think brad makes looms for exactly what you want. Secondly, get a kmon and hook up the knock sensors so you have knock warning.
Ditch the charcoal canister, just get rid of it. Like GONE!
You should look at converting you brake to have no booster as well.
Also my turbo mani and dump are off for you along with lines. It also looks like part of my oil issue with that turbo is oil pullin in the return just out side the block which would have popped the seals.
nice work. going to slam the wiring yourself hey? i cringe, it sounds painful.
Hahahah yep, good thing with the microtech is that its quite simple, no VCT wiring, No AAC valve, etc etc, so its just injectors, ignition, fuel pumps and the CAS, although I have heard that the altenator needs to be hooked up to the dash light otherwise it wont charge....that sounds like an old wives tale to me though, guess I will find out
Brake lights are easy, headlights will just be a switch on the dash same with wipers
Charcoal cannister is long gone lol, just gotta remove the lines now. I thought about no booster, but my knees are fubar, and i sometimes struggle on track with the booster, so non assisted brakes are a no no.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
