Hi Guys,
Im very close to finalising the last of my machining for my new engine and have an oil system question. I have built quite a few high performance VW engines and one of the things we do with the oil systems is to use an oil pump that doesnt return oil to the crankcase. Instead it pumps the oil to an external fitting where its routed via a remote filter and cooler. They call this a full flow oil system.
So, ive heard of RB26's that use a deep sump extension with an external oil pickup. The approach would be to dril and plug the engine block's oil pickup gallery and then drill and install a fitting in the pump to allow a connection for the line that comes from the sump. I think this was done on the bathurst GTR's.
Has anyone tried doing anything like this with the output side of the pumps and then returning oil directly to the block? The advantage would be that you dont have to use one of those remote adapter attachments, and the oil hoses would be a bit shorter.
Cheers,
Ian
Edited by GTRNUR
Nothing even close to a dry sump set-up.
Done plenty of the pick up sides but never done it with the pressure side.
I cant see any reason why it wont work the only advantage is like you say slightly shorter oil lines for the cooler and no need for a filter mount on the block.
Its alot of friggin around when the original gallery works fine and filter mounts are not that hard to use.
On a race car I could see some small benifit in making things simpler but for general use I cant see the point.
Edited by Risking
Well it seems I may not need to do this anyway now.
The oil filter block I have sourced had a large metal cylinder with to hose connections on it. If im not mistaken this is the oil cooler attachment with the built in oil thermostat thats used on the N1 GTR's right?
While drilling and plugging galleries might seem like a pain in the ass, ive actualy had that done to all the galeries anyway so I can clean out the block properly. The block has had a lot of metal shaved out of it and I dont want any of that in the oil system.
Yes thats the OEM oil cooler.
Your better off pissing it all off and screwing an oil filter thread straight into the block and doint it RB30 style with the oil filter mounting plate straight to the block.
We dont run those OEM coolers with aftermarket cores as well.
Found they allow way to much oil temp variations depending on heat soak in the cooling system etc.
There is a steel sleeve in the block that normally has an o-ring seal onto the inside of the filter mount.
How do you screw the filter straight onto the block, or do you mean use the filter mount and just dont connect the coolant lines to the oil cooler side of the mount?
I thought of doing that while my motor was out, sounds like a good idea.
You could always get a plate made up with dash fittings for the oil cooler that bolts up to where the standard one does, like a lot of SR20 guys do
You need a double threaded fitting to replace the one with the push over o ring setup which allows the use of the oil cooler block.
Rb30 has this double threaded fitting...
Ah... so that fitting in the block is threadded in and not pressed in then. That makes more sense.
I wouldnt even bother trying to source the adapters new, i tried that and instead raided the rb30 collection (different thread size each end). To get them off the block just go buy 2 half sized nuts and do the old double nut lock trick.
Pic show what i did: Got the sandwich plate from mscn http://www.mscn.com.au/scripts/prodView.asp?idproduct=354 part number TD1014B
yeah getting rid of the standard oil/coolant heat exchanger is a good idea. people do it all the time with SR20. tomei make one as do saurus for SR20. (pics below) you could get something made for RB26 easily enough, there would be a market for it for sure.
obviously the GTR one would look very different but you get the idea. :pirate:
    • UPDATE: Yes the GSP Axles are compatible. I installed it on my R34 today and they are working a treat! Turns out that the S13, S14, S15, and 200 SX all used the same axles as the HR34, and ER34 NA models. Which is 2 bolt x 3 pairs.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
