Hey guys,
i had created a similar topic yesterday but it has dissappeared.
i just want to find out if its possible to find an
R33 GTST Series 2 Manual with low Kms.
where can i find one?
i need to get one soon and cant find the right one.
which import dealers do you guyz recommend and will they sell them for around 12000 or its not possible to buy and r33 series manual for that much?
cheers for the help guyz
PS: Mods, if you delete this atleast let me know, so i dont write again.
Edited by Nismoism
https://www.sau.com.au/forums/topic/281079-can-i-find-an-r33-series-2/
When I looked around at dealers about 6 weeks ago I couldnt find any r33 s2 gtsts in manual for under 15k, the ones in good condition with low kms were even more than this at 17-18k, I didnt even bother trying to talk them down cos I only had 8-9k to spend on my car so I'm not sure how flexible they are on their prices.
Also, I think something went wrong with the server and a few threads and pms were lost, it wasnt a mod deleting your thread.
Sometimes I wish I got a slightly larger loan and got the Toyota Chaser JZX100 instead, but I'm happy with the car I have.
I picked up mine (basic supporting mods and highflow making 300hp) for $14k, so it can be done. Look around and you'll find something in your budget.
Otherwise, look for other cars:
S13
S14
Cefiro
GTiR
Stagea
WRX
Turbo Liberty
Mk3 Supra
Chaser
Up to mate, don't let us tell you what to get.
FC RX7
i dont know what to do lol hahaha
Went and saw an r33 Series 2 1996 Gtst
SLIP
ALSD
Just imported and complied
With Bodykit
1 year warranty
60,000kms
Serviced
14999 G's
it has a small peel off on the bumper the size of a 20cent coin which didt look bad.
feel like gettin it over the weekend.
Buy or Not Buy?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
