$20k for my skyline at the pub. he was dead serious and said he had been past my car every day seeing it being done up in my car port. he/we were drunk as but i still said no. i love my car to bits and it aint going anywhere until im finished with it! sorry buddy!!! i know if someone gave me $20k i could buy any c210 and get it to where i want mine to be but it just wouldn't be mine, would it?... me and that car have been through a lot together hehe
he's gunna have a proper/sober look at it on saturday lol.
https://www.sau.com.au/forums/topic/281290-ahhh-man/
i had a good think about this today (and sobered up!) and im gunna sell at that price definately. it would be f**king ridiculous not to really.
im gunna see him tomorrow about it. hopefully he still has the same enthusiasm!! he wants to go down the big block V8 path. which is fine with me, i just dont want it to end up in Arabia!
https://www.sau.com.au/forums/topic/281290-ahhh-man/#findComment-4742732
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
