Just to add a bit of fuel to the fire! I had a bit of time up my sleave and was bored so I made up this graph. Now it's not perfect, there are different dynos, different boost levels, different correction methods etc etc but it gives a decent indication of levels of response and overall power on stock stroke rb26's.
Green Line - 2.6L Garrett T04Z 0.84 (24psi) on modded china manifold, HKS 272 10.25 cams and decent head porting
Yellow Line - 2.6L Garrett T04Z 0.84 Split (24psi) on 6-boost split manifold, JUN 272 10.5 cams and no head work
Black Line - 2.6L Garrett 3582R 0.8x T4 rear (28psi) on china manifold, TOMEI 270 10.8mm cams and no head work
Blue Line - 2.6L (the motor from the yellow line) but with Garrett 2860-5’s (24psi) on 6-boost low mount manifolds
Pink Line - 2.6L with HKS GT-SS (18psi) on Tomei manifolds with Tomei 260 9.15 cams with head porting
Anyways a picture tells a 1000 words (sorry about my shocking excel skills)
Edited by Cerbera
https://www.sau.com.au/forums/topic/281368-rb26-dyno-comparisons/
I'm not trying to discredit what your trying to do - but different dynos, different days, different strapping methods, different setup methods, possibly different rolling diameters, different drive ratios, different tunes, different cam timing, different ramp rates, different tyre temps - the list is endless!!!
I can tell you from expereince that on a Dyno dynamics dyno that even getting consistant runs from day to day with no modifications performed is a task in it self. I usually get within +/-2.5% of the previous runs with the methods we employ with no changes. You need to get all these cars on the same dyno within 2hours of each other for real comparison. I would get the tacho numbers precisely calibrated so you can compare in rpm not vehicle speed.
Dude, everyone knows that (it was only a matter of time before someone jumped on it), it is just a rough comparison for people to see, we are on a forum not in a laboratory.
Keep the comparisons going, can you put "twoogle" on there, I am sure Paul won't mind.
Mike
Mike
I just dont see the point in comparing when for example there could be the difference between the 35R run on a happy dyno when compared to a TO4Z strapped tightly on a low dyno and they both read the same power now is that to say that the 35R is the same size as the TO4Z???
Thats why I hate these threads becasue the results are arbitary!!!
i said pretty much exactly the same thing in the original post... i have accounted for a few things you have listed though
tacho numbers are directly proportional to rpm... this graph actually translates 2 graphs from rpm to road speed, i can repost it in rpm if you like!!!
Edited by Cerbera
Mike
i cant find a twoogle graph in rpm and the ones based on road speed seem to be in 3rd gear (he has a os mission so i dont know the road speed/rpm relationship)
Yes but different cars may have different diff gears and tyre rolling diameter so while 4th gear is usually 1:1 the rpm/rev ratio may be different car to car.
What is the purpose of this thread??? Are you comparing turbos or engine setups or what?
all 3 cars done by road speed were r32 gtr's with 1:1 4th gear ratios, 4.11 diff gears and very similar rolling diameters (2 exactly the same) the other 2 cars were on rpm... i know the rpm relationship between speed and rpm in the r32 gtr's so i can translate from there...
turbos comparison mainly, most the motors have very similar specs
Edited by Cerbera
the red line i added is a rb27 with t04z on 22psi and pump fuel and only revved out to 6800rpm roughly on that run (misfiring above that so we called it quits), usual redline is 9000-9500rpm. This dyno reads very low too compared to some of those numbers on there :angry:
Edited by unique1
looking at the graph however inaccurate it may be the yellow line twin scroll t04z setup looks the bees knees compared to the others. same response as the 2860's and loads more top end.
I still can't decide what turbo choice to go for with my new build. 26/30 twins or twin scroll is the question ;) response is the main goal but i wouldn't mind getting 350kw+ i was origionally thinking of slapping some ss's on there. be nice to have the cash and your own dyno to change them all over and pick :happy:
Edited by GT-RZ
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
