Anyone else see the 200sx on the Kingsway this morning about 4:30am.
It was stuck on the tram tracks, cops were there taking photo's of it.
Poor bast*rds.....but what the hell were they thinking.
Nissan Attempting to take over Melbourne Transport system :down:
cant be worse then connex :)
https://www.sau.com.au/forums/topic/281423-derailed-200sx/#findComment-4744194
i've exited the crown tunnel on kings way to see a car drive along the tram lines below at night only to see it drop head first when the concrete ends and gravel begins..lol they enter from city rd underneath looking for a way to get onto kings way so the cemented tram lines look like the obvious way to go...ha little do they know.
https://www.sau.com.au/forums/topic/281423-derailed-200sx/#findComment-4744548
Also saw a 911 Carrera S smashed into the Albert Park Gold Club fence on Queens Road this afternoon.
Saw this also, don't know how he managed to do that! The car was literally lodged on these massive boulders on the golf course. Can't picture how it might have happened. :P
https://www.sau.com.au/forums/topic/281423-derailed-200sx/#findComment-4745628
    • Whilst the brewery had good beer, I didn't rate the pork knuckle, the meat was good, but, there was no crackling, the skin was just thick and chewy Will return at some stage for the beer, but, I will wash the beer down with chips Plus, no sauerkraut, in what world do people serve pork knuckle without sauerkraut, they did serve apple slaw with it, which was nice, but.......#sauerkraut the world
    • Wow yeah ok. Given how specific you are about your car, I'm very surprised you are happy to do that.  As a bare minimum, without having a wideband gauge in the car or running it up on the dyno to check mixtures, there is no way I'd do that to my car.  You beat me to it, was going to say just this.
    • Yeah - that's not true. Larger turbos flow more at the same boost. By definition. I've always found it funny when the claim of same flow same power because same boost is made. The turbine is larger, therefore will put up a lower restriction to flow at any given flow, cf the stock one. Hence, you need less boost to make the same flow through the whole system. Hence, when you have the same boost as before, you must have more flow. -5s are a pretty decent bit bigger than stock.
    • That's basically how I've been driving my R33 for a while now. GTIII-SS running wastegate boost. It makes no more power than stock because the turbos aren't flowing any more air than stock. Eventually though I need to fix this so it can actually drive as it should.
    • If this was my own car, I would pull about 5 degrees off the CAS, run a wideband, and if that seems ok, send it.
