Did a photoshoot for a friend of mine.. Will only post up 2 for now, as i dont think she wants all her photos posted across the forums lol..
- Yup no skin processing as we both didnt want to do it.. We wanted natural looks and skin tones. Hope you like it.
Edited by siddr20
  • Replies 187
Posted Images
i meant te skin smoothing or whatever. her laugh lines and stuff really add character to the photo.
Yup exactly.. Thats why i dont like airbrushed pics.. Takes away the persons character and self image i guess..
I like the 2nd one best. Woulda been better if her hand wasn't cut out of the frame though...
I know.. Didnt see it when taking the photo :rofl:
Two more pics from the yesterday:
Edited by siddr20
bnr#@ - You have a beautiful dog!! what exact breed is it? I like this series of pics. captured nicely :)
GoldZilla - :) hehe yea probably too much angle in the shot.
She needed to turn her head a little bit more to her right as well as her left eye is under-exposed but it's really only a minor thing. :down:
You've done well. :ermm:
Cheers
Not mine, its a friends, hes cool though.
Its a rhodesian ridgeback so big bugger...
Ian - Didnt notice that will you pointed it out just then!! Good eye!! :P hahah
bnr#@ - goes to google to search more about it.. I always wanted a dog lol
Slim - AHAHAHHAH so true!! Will keep that in mind for the next shoots i do.. Cheers man
Few more pics of Jori:
Im off to bed now.. peace out!!
Edited by siddr20
i like the 2nd one, looks great!
speaking of dogs, playing with a friends 50mm 1.4 AF pentax lens to compare it with my old manual...
looks pretty good. but i still think the old one has more sharpness to it :P
Ian (Xmetal) kindly lent me his f/1.8 50mm Canon lens to experiment with, and I was using it to capture some water shots I've been experimenting with, and learn more about my camera and its controls in the process.
Anyway, a few hours before I gave it back to him (thanks again, man!), i went out to experiment with different apertures to see what results I would get regarding depth of field... My old man had his car parked out the front, and it was a good time of day with the sun starting to set, so off I went outside with camera and tripod... I haven't done any post-processing on the shots.
Here are the two extremes of aperture and how they affected the DoF in the shot;
f1.8, 1/500 shutter speed, ISO-200
f/22, 1/13 shutter speed, ISO-800
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
