Hey guys, I'm looking for a car as I'm getting my license soon and have made the decision to buy a skyline. I have a limit of $10k.
The problem is I don't know if I'm being ripped off here or being sold a lemon. I've seen a 1998 R34 GT for $9200 which I reckon I could haggle down to $8500 maybe if so I shall buy it.
I'm not too positive though as all the other R34's are going for around $11 - $13k. The car is a Japan import with only 94000kms on the clock which is also really low for this price and its age.
It's all stock I can only assume and silver. I have seen another for $9500 with 145000kms which is a P plater selling the car so I'm not to sure whether it'll be a lemon or not but I would prefer to buy it as it's white looks hella sexy and already has a head unit installed saving me the time and money to do so.
Just wondering what you guys would do in this situation, I will probably try to have a look this weekend and see that the body is all good and sus the whole car out after reading the buyer's guide on here.
Cheers.
https://www.sau.com.au/forums/topic/282005-quick-opinion-on-buying-a-car/
It's your 1st car.
One thing about 1st cars, is that it will always be remembered :whistling:
But, it needs to be remembered with affection :laugh:
And never ever as a :domokun:
Take mechanical & panelbeating brains trusts with you on your 2nd visit.
Each of you have a list of things to check - whatever the car !!
I would prefer to get a 34 over a 31 more appealing to me, although I haven't seen many 31s. Yea I'll try to get a mechanic to come with me or take in into shop for a quick checkup then the panelbeaters. It looks in good nic in the photos but they can be deceiving i guess. Originally I was looking at a VZ Commodore but there to stereotyped and common, not many people in my neighbourhood have Skylines want to be unique :)
I would prefer to get a 34 over a 31 more appealing to me, although I haven't seen many 31s. Yea I'll try to get a mechanic to come with me or take in into shop for a quick checkup then the panelbeaters. It looks in good nic in the photos but they can be deceiving i guess. Originally I was looking at a VZ Commodore but there to stereotyped and common, not many people in my neighbourhood have Skylines want to be unique :rant:
So far - so good.
Get the VIN# and get it fasted here to see if its history has any 'HRT'
HRT = Hormone Replacement Therapy no not this one.
HRT = Holden Racing Team no not this one either but,
HRT = Hokkaido Rust Terminator :)
Anyways, your panelbeater can tell if there's any rust
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
