I called into ATP today for a highflow after removing my turbo, what a job. There are a few bolts that were obviously never meant to be accessed without the engine out, took me around 3 hours.
Kip the owner of ATP is a top bloke, easy to talk to. He helped me choose the right combination of wheels for the power I wanted and showed me how they go together with another one he was doing at the time.(thanks Jason) I would love to go back in when the assembly is done on mine just to say "I rebuilt it" :)
Suspension is next, I have a shiny new set of BC racing coilovers to go in, from just jap. I tried to upload a pic but no go.
https://www.sau.com.au/forums/topic/282170-highflow/
So where are the details and pics of your turbo?
Secret mens buisness apparently, no cameras allowed. :( I did ask for you.
I was going to get some pics of the car too, but theres not much of it left.
Heres a pic of the coilovers tho.
https://www.sau.com.au/forums/topic/282170-highflow/#findComment-4752356
10/8? thats gonna be VERY firm you know?
Yes, but no.
Most M35 suspension is over 8 for both.
I know the Nismo's have over 9 at the rear.
The only suspension I can think of (off the top of my head) that is under 8 for front and rear are the Kenstyle which are lowered and around the 5 mark - which is waay too soft imho.
Edited by iamhe77
https://www.sau.com.au/forums/topic/282170-highflow/#findComment-4752411
i guess its a heavier car, and you might be able to adjust the dampers to 'soften' the ride a little.......
i still think its gonna be a teeth rattler and a boob hurter. my yellow s15 had effing hard suspension and no girl would get in it as it really hurt their boobs. you dont wanna risk that in your shagin wagon :(
https://www.sau.com.au/forums/topic/282170-highflow/#findComment-4752435
I went back to kewish today just to stop you buggers whinging. The box is empty. :P and so is under the car. I will get some secret pics from Kip's workshop if possible. He rang me today and talked me into a larger again turbine wheel, bugger, I hope theres not too much lag. should be good for 250 or more, if I want to go that high. The box will handle it at least.
https://www.sau.com.au/forums/topic/282170-highflow/#findComment-4752869
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
    • planning a r34 rb25 de+t with some other work, rather just have it done in a shop due to space limitations any recommendations? I have most the parts already I seen online Moore Performance and DR Drift any advice appreciated thanks
    • I’ve read the previous posts so just looking for latest information on how people have dealt with front facing plenum is it a defect etc or didn’t pass roadworthy or was it not noticed? Have a r34 and deciding if I should make a hole on the driver side or not.  I know some people have said blitz return flow but I might get rid of the stock intake down the line for a plenum so I rather set up for that now plus I already have a standard Intercooler. Car is mainly stock  Thanks.
    • Actually, if having and keeping the stock ECU is the plan, the correct answer is to put Nistune into the ECU and improve the situation, not just look at it.
    • Wrong side of sydney for me coming from Goulburn, but you should head along, all ages of Skylines will be very welcome
