Engine Crane
Damo_c
 Share
Id prefer to buy one then rent one as i may need it a lot. Id like to get some different prices, il get a price from super cheap, anywhere else anyone???
My engine crane that i have at home is a Trade Quip TQ1001 purchased from Bursons about 18 months ago for about $400
We also use the same type at work (mechanics) and it has been going strong for about 3 years.
Due to its 3 sets of wheels, when folded it is still easy to move around and dosent take up too much room.
Link.....
http://www.tradequip.com.au/products/produ...php?code=TQ1001
https://www.alltools.com.au/shop/index.php/...1000kg_Foldable
looks like the price has gone up a bit, but you can shop around to get it abit cheaper.
Try Alltools, Bursons, REPCO, Super Cheap, AutoBarn. Basicaly any tool or auto shop should be able to get one for you.
Cheers
NutR33
PS
I just found this on Ebay, looks excatly the same as mine.
http://cgi.ebay.com.au/2-Ton-Engine-Cherry...id=p3286.c0.m14
the supercheap ones bend!
my brother use's one on 4 cyl's often but its a pain in the @$#% and the boom length is crap, to pull or fit the engine on my old vl turbo i had to remove the bumper just to get the length, yeh and i bent it pulling out a v8 so they are compact but your better off hiring.
what area are you in ? there is a guy in sommerville sell's top quality well built units, got mine for $340 and it has 6 wheels, with raisable legs, ive had it for a few years now and no prob's. gets used every month too :P
i live in melton but it looks like 350+ sounds like about what im gunna end up paying. I just found out my bro in law should be able to get 1 cheapish for me. Ive seen the ebay ones and they're going for around 300 but i just dont trust the welding on them, the last thing i want is for the engine to fall on the ground after its been hoisted. Its for a 253 V8 pulling out with more then likely a 350 chev getting put on it later, not sure on the weight of one of them but it would be heavier then 400kg im guessing, would a 1 ton be enough being when its fully stretched out that it wouldnt be a 1 ton capacity? I hope people know what i mean.
1 ton capacity could mean it could hold the engine there for along time when the arms arent stretched out but when fully extended its capacity could only be 500kg.
Also, would it be better for me to get 1 with a engine stand rather then have the hoist holding the engine for a few months?
This is the first time ive pulled an engine out of a car so if its works the way i want it to ill pull the rb25det out of mine and see what i can do with it.
i had my RB26 motor on the crane for 6 months
month it was ok,
then the jack slower went down
then i had to pump it up every couple of days
not sure of the weight of an RB26 guessing around 300 - 350kg anyone know ?
i have a 560kg engine stand for sale,
i never got around to using it, so its in new condition
pm if your interested
 Share
    • Cheers, It must be close enough coz I can’t even tell where u painted. Did u do the whole top of the strut tower or just a patch somewhere?
    • Hey all. Looking for all of the carpeted trunk trim for my 95 GTST coupe. I’m having a hard time finding the pieces I need on US or Japanese sites/auctions and was hoping someone has a clean set stashed away somewhere?
    • New aerial is aerialing well....trips into Goulburn are not losing the ABC classic radio signal Also......I've been procrastinating about wheels for the MX5, the car doesn't need any more tyre, I just "want" different wheels, so I went looking for something that legally fits the new Pilot Sports +1 size 215/45 17 that I'm currently running on the 17x7 OEM wheels (stock size is 205/45 17), not a silver, and not a black, ended up with gloss bronze Konig Dekagrams in 17x8 +40 which fit without the need for rolling the guards, whilst larger than the OEM wheels they are also lighter than the OEM wheels, and at just under $1300 for the set I'm more than happy with the price I seen a set of matt black Deka's on a MX5 when I was at MX5 Mania, same wheel size, same tyre size, sat really nice, and not stretched enough to look aids, although the 215/45 17 is the smallest that you can legally fit Just need to find some good black wheel nuts to suit
    • So I decided that I wasn't happy with how I originally wrapped the loom with fleece tape. I didn't factor in the new intake manifold/plenum so it always sat a bit funny. Yep, I decided to unwrap it and redo how the wires would branch out. Added in a light twist too, here's hoping I didn't snap any 30 year old wiring because FML if I did. Took a few more photos of the shit box too, needed it for Enthusiast Insurance as they wanted photos to justify why my agreed value was above market by a fair amount.
    • if wanting reliability and that level of performance a dry sump is mandatory for circuit stuff as you'll just be filling the head with oil. easy and reliable setup with potential for more later Hypergear bolt on turbo or a g30-660 with T3 rear housing .92 external gate mod to factory exhaust manifold with 45mm waste gate plazmaman/pwr intercooler oil cooler 1200cc injectors 460 TI/walbro with upgrade relay and wiring/pwm control turbosmart fuel reg Link g4x plug in ecu with knock, oil, fuel pressure sensors, 3 port mac valve, DBW conversion Quality clutch kit- NPC is what I've used for a long time READ THE WHOLE OIL CONTROL THREAD Could do major service while there and maybe headgasket, studs and valve springs. as soon as you whack a massive turbo and short runner intake on a street car they are useless and not practical the above will be a fun and reliable 400-430hp on E85 all day with correct maintenance and mechanical sympathy.
