This might've been asked already but were you able to keep the A/C?
Nah no ones asked it before!
lol yeh i kept it. Full climate control system works perfect. I had to bend one of the aircon lines out of the way of the dump pipe, but other than that, didnt touch the A/C system...
The only thing ive lost is cruise control due to the mechanical throttle conversion. But I think i can live with that :)
  • Replies 236
Hey guys.
Took the car back to Andrew for a touch up tune.
My car was cruising a bit lean so he put a bit of fuel in those load points, then took some out under load cos it was a bit rich.
As normal its not accepting much ignition timing at all... This is prob cos of the heat that this crappy turbo is generating.
here's the maps of the boost vs power and AFR and power:
*note the wastegate that cant control boost, the wastegate is set @ 6psi, but it rises to 11psi!
its not an issue though cos its tuned for 11psi and never spikes more than that...
So I'm still making 190hp with a blown turbo! haha
I've lost about 25hp from the initial run of 212hp.
The important thing is, its making 140kw at the wheels, where stock it makes 80kw (tested by some guys in sydney) :) thats still a 75% increase in power over stock :)
RE: new turbo: I've settled on a GT2860r -7 commonly known as the great disco potato :banana:
They are rated @ 180-310hp and ill aim to run 8psi and make 220-230whp or 170kw ;)
Should have it in a few weeks then I'll go back to Andrew (again!) and have another power run :banana:
Stay tuned!
What ya mean whens the world gonna see it!? Ive bin boosting around for the last 4 months! ;)
I'm planning to rock along to the next SAUWA cruise, im keeping an eye on the events section!
As for whoop ass wednesday, im not too sure...
I just dont have the money to replace things if anything goes bang...
having said that i have been giving it a raping on the street and apart from the turbo, it hasnt looked once like its gonna give up!
So it should be ok for a run or two at motorplex, ill just have to wait till the new turbo is on, tuned and ran in etc...
Hey. Update time...
My turbo is well and truly shagged. Blowing more and more smoke by the day...
Not to worry though! Mr. Garrett to the rescue: 23659_415684987904_526132904_4767179_1362572_n.jpg
That's a 350hp GT2860rs with a 0.64 A/R.
I'm predicting the response and midrange on the QR25 2.5L is gonna be off the scale.
Hoping i can still make north of 250hp on not much more than 10psi.
It's making 212hp on 11psi when it first got tuned, on a tiny, crappy VG30 turbo... Hopefully with a bigger one turbo ill pick up a bit extra due to better exhaust flow, and less charge heat will allow andrew to add in some decent timing as opposed to the <5 deg that ive got atm under load :cool:
For the conversion, so far ive got: t28 and 5bolt dump flanges, gaskets, cooler pipe couplers, oil drain flange, oil fitting to fit existing line and GT28 turbo and water lines.
From here all I need to do is:
-rip off the old turbo and manifold
-get t28 flange welded onto current manifold
-get dump modified for 5bolt flange, where a 4bolt sits now.
-modify oil drain to suit new turbo
-install water lines and tee into heater hoses
-source 480009 - 9 (7psi) actuator (stock one is for 13psi - too much for now)
-install boost controller and set to 10psi
-tune
I'll post updates as i get them, cos THIS is what i should have done in the first place instead of this VG30 fail of a turbo...
Stinger 4424.
I love it. Havn't had any dramas at all! It was a dream to install, got everything working first time, felt very compatible.
Only thing is the electronic throttle fvcked up, but i knew what that was...
Andrew from Hyperdrive has been doing it all, hes the one who recommended this ECU.
From what I've seen/tuned/adjusted its great!
The softwares easy to use, the datalogging more so, havn't had an inch of tune drift or anything wrong tune wise.
That's more a credit to Andrew though...
Why do you ask? I've heard a few ppl bag them out, but I'd use again!
Cool, good to hear.
I ask becuase the 6860 is on the list of potentials for my race car..just gott weigh up whether buying the ECU and then having to buy ignitors and even the loom seperatly is worth it compared to paying a few bucks more for a haltech PS2000 or wolf v500
Yeah the motorsport series are even better than the Stinger, more features and better resolution maps. the depth of tune is pretty amazing!
Plus theyve got wideband input too, which makes them that much easier a to tune and analyse.
I dont know about Volf computers, i didnt look into them much when i was searching...
What engine is in your race car?
Have a look around some forums and see which computer suits to your engine well, and what others have done...
Most people wait at least a year before they upgrade their turbo >_< Jks mate.
How long will that take to get to get it up and running, man? Hopefully you can get it to Kwinana before they close for winter! With any luck (and my license back) I'll be able to get down there myself.
Most people wait at least a year before they upgrade their turbo wink.gif Jks mate.
im hoping 2 weeks rhys...
all i need to do really is modify the exhaust mani and the dump. the rest i can knock off in half a day...
then hyperdrive can do the tuning, thats it!
still gotta sort out a wastegate actuator though, need a garrett low pressure one, not the high pressure one thats on it now...
as for kwinana, im not really that keen until EVERYTHING's 100%, im still a while off yet.
Ok, seriously, is my car THAT hated by everyone or am I going crazy?
I just had some guy (who will remain name-less for his sake - and because i have maturity) just PMd me, and said: (i quote) "you car is gay , im thinking of putting a turbo on my mums car as well ." (unquote)
I didn't know my car was hated that much that someone would go out of their way to express that.
And he owns a GTR too, no shit your car is better than mine, you don't have to exclaim it to the world.
Dont worry about those guys...snotty nosed GTR owners are a bunch of poofs anyhow
LOL.
Name & Shame + Report Abuse.
Don't worry about these tossers man, I get it all the time "bunky" - "thats ALOT of work man, not even worth it", peice of shit, my bog stock r33 "gtr" (gtr, gtst, same same) is fasterrrrrz lolz. These morons don't even work on their own cars. Fully sick workshop stickers on my quater panel ulleh, more horsepower.
If this guy had a GTR, or balls, he'd post it, not PM you.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
