Hey all
Have the following items for sale
They are taking up alot of room and parents have lost the plot so need Everything gone...open to all reasonable offers
R33 S2 Front seats
Passenger side is immaculate, driver is worn on the part where u get in and out
$150
RB20/25 High Mount manifold
38mm Wastegate Flange
Was fitted to my car previously
Has been ceramic coated in black
$100
JJR 38mm Wastegate
In great condition, was also previously fitted to my car, never missed a beat
Had a new diaphram put in December, hasnt been used since January
Also has a 10Psi Spring
$100
RB20/25 Adjustable Cam gear
$20
R33 S2 Standard rear spoiler
good condition
KR4 Silver
$50
RB25 Camshafts
Both inlet and Exhuast side
Inlet retains VCT
Im not sure on the brand, but previous owner stated that they were 265's with 10.5mm lift, not too sure maybe someone can correct me
They are in good condition
$250
Genuin Garrett GT35R
.63 rear housing
Has a 90 Degree elbow on it
In great condition
But needs a New Rear Wheel
$500
R33 S2 Standard front shocks and springs
Ok Condition
$20 or ill throw them out
Im open to reasonable offers, really need all this stuff gone
I have no use for it and rather someone use it all.......
Pics will be up Tomorow night
Please dont hesitate in Pm'ing me or posting in here
Thanks
https://www.sau.com.au/forums/topic/282967-skyline-parts-sydney/
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
