Hey all
Have the following items for sale
They are taking up alot of room and parents have lost the plot so need Everything gone...open to all reasonable offers
R33 S2 Front seats
Passenger side is immaculate, driver is worn on the part where u get in and out
$150
RB20/25 High Mount manifold
38mm Wastegate Flange
Was fitted to my car previously
Has been ceramic coated in black
$100
JJR 38mm Wastegate
In great condition, was also previously fitted to my car, never missed a beat
Had a new diaphram put in December, hasnt been used since January
Also has a 10Psi Spring
$100
RB20/25 Adjustable Cam gear
$20
R33 S2 Standard rear spoiler
good condition
KR4 Silver
$50
RB25 Camshafts
Both inlet and Exhuast side
Inlet retains VCT
Im not sure on the brand, but previous owner stated that they were 265's with 10.5mm lift, not too sure maybe someone can correct me
They are in good condition
$250
Genuin Garrett GT35R
.63 rear housing
Has a 90 Degree elbow on it
In great condition
But needs a New Rear Wheel
$500
R33 S2 Standard front shocks and springs
Ok Condition
$20 or ill throw them out
Im open to reasonable offers, really need all this stuff gone
I have no use for it and rather someone use it all.......
Pics will be up Tomorow night
Please dont hesitate in Pm'ing me or posting in here
Thanks
https://www.sau.com.au/forums/topic/282967-skyline-parts-sydney/
    • The spray cans were in the "Kiln" room whilst I was preping the parts,  so probably around 2 hours to get them warmed up, the kiln room has 3 small ovens running at 100°c, 3 medium sized ovens running 100°c, and the large one I used running at 80°c, the room itself was about 28°c, I also spent a bit of time taping up the parts in the room as well, and by the time I was done I would assume that the parts were around that 28°c As for power, I expect a couple of Killerwasps up high would be achievable with the current mods, I'm still running the MZR 2.0 intake and throttle body, and there is a slight mismatch with the 2.0 intake (smaller) and 2.5 intake ports (larger) on the head, this intake is matched and specifically designed to fix this issue with the ports mismatch, the throttle body is also a couple of mm larger, OEM is 65mm, the Bosch is 68mm In the end it will look "prettier" than the molded plastic thing that is the OEM MZR 2.0 intake As for the LSD, it's the OEM Torsen which works fine for what I use the car for, plus, basically no maintenance apart from the occasional oil change
    • I was at Tunehouse in Marrickville (great team over there really know their VR's) , and I spotted this Very clean R35.
    • Mate , I have the same issue right now with the exhaust noise , if you can tell me what your local guy did , I'll talk to my guys and see if they can do the same. Power is good but it just too loud when put it down.
    • The other trick I've found with wrinkle black is to put the can in hot water for a bit to warm the paint up, and to pre-heat whatever you're painting. It'll be interesting to see if you pick up any power with the intake, following with interest. Got a proper lsd for this?
