Hey, I just recently bought a fibreglass bodykit off this website called vivagarage. Just wondering if anyone has bought one of there kits before and how well they line up. I also got quoted $2000 to fit and spray the kit (front bumper, rear bumper, two side skirts) Is this a reasonable quote??
https://www.sau.com.au/forums/topic/283037-bodykit-quote/
I paid 900 for mine painted and fitted.
had it done in Wynnum. Not gonna advertise the guys business cause he cut the diffuser off my $550 rear bar
But maybe that comes under the philosophy "you get what you pay for"
Edited by R33_Rob
https://www.sau.com.au/forums/topic/283037-bodykit-quote/#findComment-4763160
hopefully your kit fits of the bat! i doubt it though.
we spent hours re-fitting twisted pieces, so if you could do any of that im sure it would dramatically reduce the cost if you can take it to them ready to go.
good luck :P
https://www.sau.com.au/forums/topic/283037-bodykit-quote/#findComment-4766077
I bought a rear bar and side skirts from Viva for my stagea.
Took me about 40 hours to make the rear bar fit. Had to be cut into 3 peices.
Both side skirts had to be lengthened as well.
Good luck
40 hours?? did i read that right? lol that's insane! yea viva garage is the only place I could find that sold the full kit for a 4-door r33 so I'm hoping it doesn't involve too much work otherwise i'm not gonna be too happy. and yea this is the first quote I've gotten so far. The place that quoted me was 'auto collision repairs' at seventeen mile rocks..the first place I've been to that actualy gave me a quote lol
https://www.sau.com.au/forums/topic/283037-bodykit-quote/#findComment-4766154
thats damn cheap man spill the info ill take 3 of em
https://www.sau.com.au/forums/topic/283037-bodykit-quote/#findComment-4766418
Smick panel and paint on the gold coast are doing my veilside front bar, side skirts, and rear pods for $650 painted and fitted. and I think hes doing my grill for free
Earlier in the year I got a TR bar off carmate and it wouldnt bend in enough to fit flush so it cracked and had to be repaired and they have been ignoring all my emails. Hows that for customer service.
https://www.sau.com.au/forums/topic/283037-bodykit-quote/#findComment-4767607
buying from monkey where house is the same shit from buying from dmd..
in the end its warped..
pm me if u want me to help u find the right places for bodykits.
DMD does sell genuine bodykits, I got mine genuine URAS/Blitz D1 wide bodykit from DMD and the kit fits perfectly without dramas at all.
Anyways back on topic, my recommendations are:
1. Cameron's Body Works
Phone Number: (07) 3277 3475
2. SMC Kustoms
Phone Number: 0417 002 376
3. Unique Auto Styling
Phone Number: (07) 3889 3669
https://www.sau.com.au/forums/topic/283037-bodykit-quote/#findComment-4768575
i payed just under $15,000 for a kit and to bare metal respray. but thats with custom molded guards and like i said to bare metal.
at the end of the day, you get what you pay for and when it comes to paint, every mofo will pick it like they know every thing about paint and have bought the best of the best.
my advice, decide what sorta quality you want and then decide if thats an acceptable price.
with paint. you get what you pay for. hope this helps.
https://www.sau.com.au/forums/topic/283037-bodykit-quote/#findComment-4768591
yeah just dont get them to fit it.
personally send PCE a message, that where i last got my hookups from.
and yes you do get what you pay for, just look at the JSAI shit !!!
Edited by 32_Dave
https://www.sau.com.au/forums/topic/283037-bodykit-quote/#findComment-4768600
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
