Hey guyz, I just wanted to know where can i get an o2 sensor for my R34, and where is the o2 sensor exactly located.. my mileage is pretty low so planning on getting it changed...
The 2nd thing was Where can i get a 0.8mm Spark plug for my R34 and how much does it cost...
Thanks guyz for all the help u can provide!!
I use NGK BCPR6E spark plugs.
Get them from repco, supercheap, autobarn etc for a couple dollars each.
Got 6 of them around the $30 mark
O2 sensor is on the dump pipe on your exhaust. (Look at your turbo and follow the dump pipe coming out, the o2 sensor should be plugged into the pipe.)
Not sure what model o2 sensor you would need for a r34 but expect around the $100 ish mark for one.
Or trade price should get all of that for around 100 bux :( oxy sensor is 77 IIRC, and plugs were either 11 or 22 for 6
Hey James, by the socket u mean the plug rite?
Yea man, not sure how much you know but basically your O2 Sensor looks a little bit like this (different socket)
Because of the wire you cant just place a regular socket over it and because of the placement it's a pain in the ass to use a regular spanner
55540.jpgI Have one of these if you want to borrow it or you can bring your car over and we can just do it here, makes your life sooo much easier
What mods are done to the car?
If running a standard-ish setup, you should not be buying 0.8 - rather 1.0 at the least, could be one of your reasons for not-so-good economy.
Also get it on a dyno, see what the AFR's are doing. Could be a fuel reg slowly dying out and so on
Well i just got t dynod few days back and it has some basic stuff like pod filter,boost controller,cat back exhaust,blow of, and Apexi AFC, so evrything has been tuned and the tuner told me to go for a 0.8mm plug!!
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
