got carjacked in broadview at 11:30pm by ~3 aboriginals.
if you see my Midnight Purple R33 GTR rego "BIT SUS" please call police ASAP
BLACK PLATES, SILVER LETTERING (BIT SUS)
Work Emotion XD9s,
big trust intercooler
cannon
MORPOWA sticker on rear window.
Cheers Nigel.
https://www.sau.com.au/forums/topic/283437-stolen-r33-gtr/
fark nigel,sorry to hear mate,will keep an eye out.if they know whats good for them they wont be cruising about in it
first the 260,now this
mike rann,putting an end to crime in our state
i think not
put up a fight at least mate?care to explain what happened?
https://www.sau.com.au/forums/topic/283437-stolen-r33-gtr/#findComment-4768815
i think not
i was being followed by a black R34 (possibly 4 door), had plates X**;** had a front mount too
followed from Victoria Drive (behind adelaide uni) to collingswood.
i had a loud clunking noise from under the car, so i pulled over in Galway avenue (just near ABC building), got out to check the noise, turned the car off then they pulled up behind me in the black 34
got my phone out my pocket ready to call my mate who lives round the corner, but got hit on the head with a spanner and told to give the phone over.
so i handed the phone over, and next minute i know they are in my car driving off. I reached into the car, tried to get the keys out the ignition while being dragged by the car.
I ran on foot after both my 33 and the black 34, and watched as my 33 did a donut, nearly went up a gutter then they both took off down Galway avenue in a northern direction.
I tried to flag down at least 4 cars, but finally knocked on a door and got sum1 to call the police.
Both my mobiles, my wallet, house keys and workshop keys are in the car.
I got a feeling the car is already torched or dumped. *cries* It had a full tank of petrol in it.
PS: it had 6000k HIDs installed, so u can see it a fair distance away at night.
IT HAS A SILVER GTR GRILLE TOO
Please people, if you see this car, don't try and be a hero, just call the police or tail the car or something.
Edited by BIT SUS
  • Like 1
https://www.sau.com.au/forums/topic/283437-stolen-r33-gtr/#findComment-4768822
This is bloody ridiculous.... we live in Adelaide not Harlem ffs!! Makes my blood boil - really hope you (espesh your head) and the cars alright. There are some absolute scum bags out there. :huh:
Edited by 32godzilla
https://www.sau.com.au/forums/topic/283437-stolen-r33-gtr/#findComment-4768874
My friend and myself were on the way home when this black r34 was following us in our skyline. they followed my friend to where he live and attacked him with a spanner.
they were aboriginal from what my friend had stated.
Beware Guys!!!!!!!!!! do not stop when a black r34 coupe is following you.
https://www.sau.com.au/forums/topic/283437-stolen-r33-gtr/#findComment-4768965
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
