:( just got my new r33 series 2 GTS25T after driving a non turbo for 1 year and i am very happy.
and i am the first owner :P
its completely stock at the moment.
btw does the series 2 have FOG lights? and if it does where is the switch?
and what body kit is this?
https://www.sau.com.au/forums/topic/283535-my-new-baby/
Those are prob the only aftermarket wings that compliment the GTS25T's... The original wings aren't the greatest and there are so many on cars that have gone way too far.
The wing you have looks great and suits the style of the car very well. Actually, Nissan should have made something like that as standard.
Nice car overall. :cool:
https://www.sau.com.au/forums/topic/283535-my-new-baby/#findComment-4774471
mate that spoiler is standard issue on the series 2 r33, many of which have been ditched for GTR copies :cool:
I think the original wing you refer to are the series 1 spoilers and yes they are a bit sh%thouse, I had a series 1 r33 and I swapped it out for a series 2 spoiler exactly like the one on the pics above
https://www.sau.com.au/forums/topic/283535-my-new-baby/#findComment-4774771
nice pick up!!
also got a unique front bar there? looks like a series 2 front bar and do luck front bar made love and yours is the result o.O
and boost is an addiction once you taste it you just want more unless u learn to control urself the wallet is gonna get raped :D
https://www.sau.com.au/forums/topic/283535-my-new-baby/#findComment-4775215
Thanks guys. :) loving it... plus its very quiet compared to my previous one. no rattles or anything. just need to lower it and also need to wash the car. haven't washed it since i got it. lol
yeah the front bar looks different and i am not sure what it is. :D
Lol Taks yeah need to control the wallet for a while.
https://www.sau.com.au/forums/topic/283535-my-new-baby/#findComment-4775428
mate that spoiler is standard issue on the series 2 r33, many of which have been ditched for GTR copies :P
Ok "mate"... I didn't realise. I owned a series 1 quite a few years back and sold it due to a business venture overseas. I dropped out of the import scene for many years so I didn't realise they were standard. I honestly thought people were swapping them out. They definitely look much better. I think the GTR wing looks the best though (luckily enough I now enjoy a Series III R33 GT-R V-Spec).
However, a GT-R wing on a GTS-t is ok but I can not stand a GTS-t trying to look like a GT-R (badges etc.).
Edited by Shinrai
https://www.sau.com.au/forums/topic/283535-my-new-baby/#findComment-4777043
all good, don't take my previous post the wrong way, wasn't trying to be a smartass to you in anyway so sorry if it came across like that :)
back on topic: I think if the car is lowered anymore the frontbar is gonna act as a diffuser aswell :P
https://www.sau.com.au/forums/topic/283535-my-new-baby/#findComment-4777622
  • 2 months later...
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
