Chinese cast iron blocks are not a nice thing from those I've seen, the same with cylinder heads. There are copies of the Dart Chev blocks coming from China now and they look good but the hardness just isn't there and the geometry apparently isn't great. There's a long thread about them on speedtalk at the moment.
Some stuff from China is really good, including many of the cheaper US branded conrods but a block is a lot more complex item. There are even fake ARP bolts being made there, it's good to know that the Spool rods run genuine ARP bolts, they arrive in the ARP packet separate to the rods. Some other rods around have bolts that look a little suss, they have ARP stamped on the head but not the finish you would expect on the rest of the bolt or no brand at all.
haha yeah i just rejected a whole lot of PROCOMP gear (heads, sheet manifold etc) as it was all junk. It is just a joke, but other gear from the right place (non procomp) is actually quite good ie stroker cranks and so forth all seem to be spot on
I read somewhere that Dart were boycotting (or getting people to boycott) the Chinese copy blocks and buy original Dart stuff.
Dart are smart, they have dropped the cost of their blocks to gain back the market, great idea if you can afford to do it. The rest of their products probably cover the cost.
The thing with Chinese stuff is, if you specify exactly what you want and supply drawings etc, then get samples, then keep a check on the quality, you get a good product at a good price. I've used some chinese 4g63 and Subaru cranks and they are not bad stuff. Spool rods, wherever Brad has them made are made to his specs and are better than the competition. He does supply specs, drawings and such for what he gets made. I know this for sure because I did a little cad stuff a while back for him.
The problem with some parts is they make them to a price rather than a quality, it used to be the same with Taiwanese machinery, it was junk, now it's some of the best around. Chinese stuff will get better as time goes on. Look at their space program, at least one out of every 3 rockets they launch now actually makes it into space and doesn't crash into a town near the launch site. One day it will probably be 2 out of 3..
i did this for my i/c silicone hose kit, worked out well in the end
haha greg what a statement lol...thunderbirds are go!
Are any of these engines with failed pumps using bypass filtration? I understand the design spec issue and tolerance theories, but the comment about gerotor sensitivity to junk makes me wonder if it might be partially mitigated by better filtration?
Edited by WizardBlack
Does anyone have an idea why the nitto pump has been changed to use a billet cover plate rather than the cast one they originally had? Call me paranoid but I just fitted one that had a cast cover plate.
the cast plate ones are fine...relax greg...ive used quite a few of them. Ill find out the reason for the change of you like. The answer...evolution...Nitto are constantly reviewing their product range to stay well ahead of the competitors offerings. Anything that can be seen to be improved will be upgraded/updated.
Edited by DiRTgarage
I'd be very interested to know Paul, thanks. The new flyer is a little better written anyway, it would be nice to know the grade of metal used for the gears, just saying "EN series" allows a pretty big variety of materials.
The pumps look the part, I still think the relief pressure they are set at is way too high though.
they are the same as a stock SR20 pump...no drama's with them...even at tight factory bearing clearances. Im happy with them after speaking at length to Nitto about it.
"NITTO has now released a new billet alloy backing plate allowing further stability to oil pressure and flow at high rpm levels by minimizing any possible flexing of the housing"
Does this mean that they were finding their original ones with the cast backing plate were flexing?
Also i remember reading from one of their previous pump descriptions that they were using EN46 for the gears...
"possible" is the operative word here. Im sure they didn't have an issue...but more the fact they wanted to prevent anything being the weak link in the chain.
yep Shane EN46.
Given that you've spoken to Nitto, do you know where the pumps are made? I'd have more luck finding Mr Snuffleupagus than info on Nitto.
I can assure you yes...they are made here on earth.
What is your concern with the pumps high crack-off pressure?
Nitto gear is not made in Germany thats for sure.
Got some info ?
Greg im sure you already know Mr Snuffleupagus is found hanging out with Big Bird on Sesame St.
Dave you typed a lot...for no response...if you have some info and you have decided not to post it feel free to PM me.
Here's Nitto's distributor website...its black and white.
http://www.tweakit.net/shop/product_info.p...roducts_id=7204
to be honest i couldn't give a rats arse if i found out they were produced by blind buddist monks in the mountains of Tibet...they are an excellent product that ill continue to use on all our engines.
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
