The VCT on OEM engines is there to give you the best of both worlds.. top end and low end. It has its' benefits in performance applications but most people don't care.. they just give it more revs before they drop the clutch :D
You guys ever driven a car that had VCT and then got rid of it? SR's and RB's with VCT removed are shit down low. Hell, RB26's are shit down low. Not that many people care about such things on big power cars, but for a daily driver it does makes a difference.
Edited by PM-R33
Maybe your VCT wasn't working because there is a difference. Considering i can control my VCT with the microtech and turn it on or off, yep, there is a difference. Good mate of mine took the VCT off of his S15 because they tend to fail on the SR20 and he regrets it, very noticable power loss down low.
I'd be curious to see how a stock turbo RB26 would go with VCT on it considering i find them quite crap down low for what they are, however that's probably just lag from the twin setup (maybe this aint as bad on a R34, only been in R32 and R33 GTR's).
Edited by PM-R33
I'm in the states right now and a buddy of mine just bought a HKS V-Cam set up for his 33GTR. It has a fairly large single and pumps out 780 odd whp. He made alot more bottom end and especially midrange power with the V-Cam system set up correctly.
I would like simmilar results for my own 26, however I don't want to spend 5-7k on a brand name item.
I have an aftermarket ecu that I will be able to use to controll a pressure controll valve, I will have to get a cam custom cut, line up some oil pasages and use a 25 VCT gam gear? Then spend some (free) time in r and d...
I'm just trying to find out if anyone has had any results (good or bad) trying VCT on a 26 head.
Cheers
J
Baring in mind turning a VCT off is not the same as running a camshaft that is designed to run without any form of VCT.
I can see VCT having benefit on the road with stop start driving in traffic etc which is most likely the major benefit of having it.
IMO correct cam choice and adjustable cam gears is more than enough. In saying this i have never had a direct comparison.
Never saw anything too impressive in comparison with that HKS car either with the 26 VCT.
VCT is not all about low end power guys, its also about the efficiency of the engine, this is due to the overlap of the timing between the intake and exhaust camshafts (small duration favourable at low rpm and larger duration at high rpm, because of the time it takes the air to get into the combustion chamber) so essentially due to the increase in efficiency this also in turn leads to increase power and more importantly torque. personally I do not see to many issues involved with fitting the vct to a 26 head, just a little bit of machining required, but no reason why it would not be feasible, We would like to see this carried out, as it may well turn out to be a good option compared to the hks system and could be every bit as effective.
good luck with it mate, and if we find that anyone has done this will let you know.
you will probably find its cheaper to just use the neo head. why reinvent the wheel?
Exactly, MUCH cheaper infact, probably to the tune of 4k give/take.
For other than the sake of "saying" you have a RB26 head, i see little point in not using the RB26 head if you want the VCT and so on. the HKS V-CAM is too expensive for what it is when you can just put a NEO head on, and get an adapter for the RB26 intake side.
Who cares what head is on there? Does it do a better job, yes. So therefore you use it.
It is the same reason why some people (including me) dont want to use an RB30 block.
If you are sure it does a better job you must know more than most...? >_<
If you are sure it does a better job you must know more than most...? :D
I was comparing the 26 head to the 25 head.
VCT vs no VCT... pretty easy especially when the thread is about - VCT on heads
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
