Ok so basically one of my cradle bushes has been leaking oil, and the car seems to feel really sloppy in the arse end, especially around uneven surfaces on corners. Is it ok to just get solid bushes fitted (and adjustable camber arms), or am I going the wrong way about this? I don't care about ride quality, I just want maximum handling improvement.
https://www.sau.com.au/forums/topic/284112-r32-cradle-bushes/
Yeah I was looking into the solid metal ones - a mate did this on his A31 and said it improved handling noticeably. It's also kind of important, since the bush(s) seem to be absolutely stuffed now (ie car feels sloppy in the rear all the time, getting axle tramp and a feeling of a loss of control when cornering too hard etc)
hows that.i had same problem in my a31.when i came on boost it felt like it was twisting the chassis.so i droped the sub frame out and sure enuff ithe rubbrs wer torn.i bort sum alloy locking washes NOT pinapples,chucked it back in and was all gravey.my a31 hd 383.3rwhp and it stoped the twist and was also running a locked diff.
so i would run wih the locking washes only take 30min to slip in as you only have to undo the subframe bolts enuf to slip them in
Ok so I ended up getting some alloy ones on Ebay, but it turns out that they are the ones which require dropping the subframe to put on rather than the 'slip on' type. The seller claims that they are a better long term solution than the slip on ones, but I'd thought they were all the same thing :S
just cut a section out the size of the bolt... it only needs to happen on the top rings and it doesnt not affect the effect.. i have done this on both my r33 and r32 and found the handling to be noticably better and the ride quality hardly changed. that is with solid alloy lock rings... not urethane pineapples.
Well as it turns out, I got the car looked over when I got new tyres, and it turns out that all the rear bushes are stuffed as well as some of the steering components ;) So the rear subframe will be removed anyway lol.
Do any of you suspension guru's know where the best prices on bushes are? I was thinking whiteline or something like that. Kind of annoying since I'd just gotten all the stuff to do the 100k service and now find out that half the suspension is stuffed too!
Well as it turns out, I got the car looked over when I got new tyres, and it turns out that all the rear bushes are stuffed as well as some of the steering components :D So the rear subframe will be removed anyway lol.
You can get Nismo one from http://www.nengun.com/nismo/suspension-lin...arts-gt-r-bnr32
Also this image will help you when ordering the bushes if you decide to go this way.
AU $ 304.71 including delivery.
I ended up getting a set of KTS Alloy Cradle Lock Collars since the guy I was dealing with on Ebay stuffed me around, one other thing, do superpro or whiteline etc sell complete rear end bush kits for Skylines? I've seen them for Falcondores, but not for imports :D otherwise I'm going to have to find the list and order it all piecemeal.
so I got a mate to attempt to put in the bushes on the weekend. However, whilst the backs went in no worries, there are bolts at the front which are rusted tight and are inaccessible by WD-40, do any of you boffins have any ideas on how to undo them? We didnt want to yank too hard on the breaker bar for fear of snapping the heads off the bolts and making it worse :P
However even with just the back ones in there was a noticeable handling improvement, but it's far off perfect.
Well as it turns out, I got the car looked over when I got new tyres, and it turns out that all the rear bushes are stuffed as well as some of the steering components :P So the rear subframe will be removed anyway lol.
Shakiel at feenin performance will get very good prices(trade) on the parts, and do a very fair price on the install. http://www.feeninperformance.com.au/?pid=servicing
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
