Hi All,
The next SAU dyno day is to be held at SST on Sunday the 7th of December, and we'd like anyone from SilviaWA or any other jap import who wants to compete to join us. You will need to complete the form and pay $30 prior to the event to be eligible. We only have limited spaces so get in quick. We're expecting to kick it off at about 10:30. We'll be having a lunch break and will be running a sausage sizzle.
There will be trophies for Highest HP 2L, Highest HP 2.5L and Highest HP 2.6L or greater. There will alos be an exhibition class where we're hoping to have a few very high horsepower cars make an appearance:D
http://www.tnet.com.au/~dantheman/Shooutou...mniform-SST.doc
https://www.sau.com.au/forums/topic/28419-sauwa-dyno-comp-sun-dec-7th-sst/
  • Replies 59
If you have sent you money and form in and your not on this list then PM me:D
Entrants:
Luv DR
Shuto-boy
REP003
MearCat
Jill200SX (SilviaWA)
Yoon Kang
DSTURBD
living backwards
Gavin (japSpec)
B_real (SilviaWA)
ND4SPD
jmp
Bully?
S13 Angel
DR30RS
I will not be running.
I just got a new clutch installed today, canna flog it for a short while....bugga!!!
Also I will come down to support and I will even pay $10 for steve to show me how to adjust my friggin bleed valve (sounds like a bit much, but thats how much I wanna support)
heck I dont mind still paying that $30 if steve will do me a power run later in the week or when I can clock up enough k's on the new clutch
i got sunburnt :cheers:
good to catch up witha few peeps ....... stoopid sun burn tho :(
Thanks for cooking the snaggers Cam ..... big thank you to SST and Paul for organising and the people that came down and supported the event :grouphug:
No probs Niz - farkin hot job it was. I saw quite a bit of sun myself.
Good work by both the postwhore and the SST boys. And thanks to all those who came along.
Paul - you going to post up a full set of results?
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
    • Yeah you can. Cable tie the gauge to a windscreen wiper, or run it into the car and hold it with one hand, or have the neighbour's kid run alongside and tell you what it says.
    • I've never understood why this bothers people. Surely you'd be looking at a T3 flanged Garrett style thing, rather than a TD? You're unlikely to push a +T hard enough to need that much fuel. If you're not starting with most of the things you need to do that (ie, the bloody ECU!), you're better off just going Haltech/Link. You wil hate life a lot less. No. Just no. Just turbo it as is.
