from memory he doesnt have a lot of time? cant remember the exact reasoning behind it... i think its just that skyline fever we all went thru trying to get our cars :D
If he's in that much of a rush I wouldn't like to see him importing one.
Sure you can get a late model (spec2 1998) for not much over $20K, but it is hard going through the 2 1/2 months of owning the car before you get to even see it in the metal and the over three months from buying until you get to park your ass behind the wheel. :D
Teaches you a lot about patience but...:uh-huh:
shit yeah the wait is long.
but with patience when looking, and patience when bidding, and patience (and a little agro) when waiting for it to arrive in Oz, and patience for it to be complied and patience for it to be transported to Melb, man is my S2 WORTH THE WAIT.
good luck by the way :D
I didn't want one with a sunroof, but ended up with one! My head touches the roof and i cant drive it with the lining closed, but at the end of the day it's a skyline :P I'm still in love :whackit:
lol thats the main reason i didnt want a sunroof... i wouldnt be able to sit in it with a helmet... and then i found out i still couldnt properly unless i laid the seat back :P
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
