  • Replies 716
Posted Images
Well Jenna’s car came in for some attention
New dash 5 turbos,
so now the n1 can go on the race car, about farken time
Out with alloy rad as the car could only do 3 laps at a time
Testing out the stock rad
New
Old
f**k you garret!
For an extra 1k you can buy hks and it comes with all the gaskets and studs
Money well spent if you ask me
How f**ken hard is it to charge 50 bux more for that shit!
And you have to mod the oil returns
Kunts!
How awesome are stud pullers
Working hard for the money
New Cusco front shock, scored them out of a front cut I bought (the Ohlin’s were on the way out at the last track day, we did)
Out with the old
I think they are alright but only one way to find out
I made jenna do it
Some fags would clean it prior to shoving it in
I don’t clean
The brakes were becoming increasingly hard to bleed so much that the last track day = us packing up early cause they were rooted. So we put on some braided lines. Then the brakes would not do anything. Turns out that the master cylinder was rooted, so new one of those
The last straw for the master cylinder
Yes it was a kunt
Then road tune complete and booked in to dale’s for a tune tomorrow
Hopefully it doesn’t explode
i have a sikness
check it
and in other news to prove that i am not gay( if owning a prado was not proof enough)
i bought a arb bull bar for the prado
looks like this( car below is not mine is just the same bar)
just getting it powder coated silver cause i am a massive tosser
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
