I Wonder If Its Good To Install One Computer For My Car
Hey everyone im new to this forum but i got a question here. Please help me out >_<
i wonder if i install one computer in my skyline GTS-T R33 , will it work better for my car...or go faster... or more stable
i forget what that computer called , its power fc or something.....i dont know, since im new to performance car, its my first sport car ;p
i currently had intercooler , air filter , HKS SQV BOV , and a wastegate on... i wonder how much HP i got , the car is fast tho.... heh...so i wonder if i install one computer will it make the car work better?
Thanksss~~
ah sorry , another thing , i wonder if anyone can help me out with installing oil cooler and which oil cooler is recommended .
r33 engine is pretty hot , i heard some friend told me that in summer my car might go overheat ...o.O
Dropby Baskin Robbins at Chapel Hill tonight to get instant answers to your questions. To answer it briefly, yes. By installing a new ecu (doesnt really matter which brand) will improve any parameter you wish. For example, you might want response over high end torque/power and having said that you'll probably will lose fuel economy at the same time too. In most case fuel economy will be slightly better as they're rich when stock.
Dan: Lmao. I was going to say I'm 99% sure he's lives around Brisbane by looking at his name when you ask him where does he live. And from his name 98% he'll be staying around Sunnybank!
i think i saw you tonight ken mate..
with ur partner..
good to meet you hopefully u can make it next thursday night :down:
hehe ye thats me and my partner :D yea lets see next thursday if im free .... nice to meet u guys too :P
goodnight!!~
Dudeman I live on the Gold Coast.......
I live a very awesome yet sheltered life lol
Sheltered life!!!! thats cos you live under-ground.
Edited by EFI Performance
Whens your car gonna be done? Coming next thurs?
Im working on Dan's car all weekend to get as much as I can done before my fabricator Pete return's back from seeing his son in hospital.
Our aim is to have it ready by Thursday night.
Whitey
Whacking a powerfc by itself into your car wont do anything and it's actually it's only got a base tune for your car and if you buy it second had which most times you will the power fc will have been tuned for someone else car. I have an almost completely stock car but with a Nismo exhaust my car was tuned to 187.1 rwkw from a powerfc which I was freaking surprised at but in the end a lot comes down the the tuner and what you want. If you want a "speed/power" tune your going to get some economy sacrificed, most people get a power tuned laced with economy just because your not going to need so much power really unless it's a track car and with fuel prices the way they are it makes sense. There are also a lot of other ECU's out i've heard some good things about Emanage but it's all down to user preference, personally I love the hand controller and love the knock sensor on it although if you get it don't bother getting the Power FC Boost controller add on I heard it's shite
Everything you wanted to know about Power FC:http://paulr33.skylinesaustralia.com/docs/...powerfc-faq.htm
    • The cross sectional area of a circular hole scales with the square of diameter. So a 2mm diameter hole is 4x the area of a 1mm hole. Not double. The 1.7mm hole is nearly 3x the area of a 1mm hole. You do not need restrictors at both ends of the oil supply line. If you have new, additional restrictors at the turbo end, that you did not have before, then you do not need a restrictor at the inlet end.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
