Anyone got some tips and pics on changing the steering fluid on a S2 RS4 stagea ?
The old fluids getting a bit blackish.
It only has front wheel steering.
I haven't had a look at it yet. Do they have a drain plug or you need to take off a hose?
Thanks in advance
Brendan
You could start by syringing the reservoir empty, refill with clean fluid, remove return line at reservoir, (usually on the side, bottom one is feed line to rack) fit return line into the top of a coke bottle or similar fluid receptacle, remove fuel pump fuse (stops engine from starting, needed for next step) get someone to crank engine as you add fluid to reservoir to replace fluid flowing into bottle from return line. Continue until you are getting fresh fluid from return line, (I'd have at least a litre or two to ensure you get it all out) Reinstall fuse and return line, check for leaks whilst running; Done!
Good luck!
Thanks Daleo
Sounds like the way to do it.
I didn't realise the fluid pumped around by cranking the engine. I thought it was just when you use the steerring wheel.
Why do you need to remove the fuse and not have the engine running? too much fluid presure ?
...because the power steering pump runs off the engine, and if you bring the pump up to speed with no pressure in the lines, you may cause the fluid to cavitate, turn into foamy smoo and and make the job 100 times harder. Cranking speed "should" be fine, but if it starts coming out all foamy then shut it down, as you run the risk of this foamy smoo getting into the steering ram and it can then take a couple of days for all the air to bleed out.
Another thing - as the power steering system is a self bleeding set up, its pretty important you do all the flushing with the front wheels in the air. The best way to bleed the air out as much as possible before driving, is wind some lock on and off. And if there is any air in there, you really dont want the tyres fighting the system when its got pockets of air and no oil around the ram.
Foamy smoo, lol, can't believe nobody spotted that one. You guys have changed...
  • 1 month later...
I finally got around to doing it the other day.
I used about 2L of fluid flushing it through. I ended up using Nissan Auto Transmission Fluid at $12 a Litre.
Only problem I had was catching the old stuff, I thought I was catching it pretty well, but ended up finding heaps on the ground.
Next up is new rotors and a diff fluid flush.
Edited by QLDR31
So did you do it as recommended? Fuel pump fuse out ect...?
Yeah I followed instructions. I also added a few of my own. Cranked the engine a few times to get rid of fuel before taking the pipe off the steering tank (The pipe I removed was the rear most pipe). I also temporarily added another pipe to the tank so fluid didn't leak. I also had a few rags around to soak up the mess.
I think I made a bit of a mess because my bottle was a bit dodgie, and I didn't have a helper to catch fluid while cranking.
well there wasn't any mention of foamy smoo..... :(
It tried hard to smoo but all it could do was a few bubbles.
  • 4 weeks later...
Mine is due for a change and I bought a bicycle pump to use as a syringe to suck the old fluid out. $2 at Crazy Clarks.
How did the bike pump go? I thought they only blew and didn't suck.
The pump will do either, there is normally a little check valve in the flexible hose on a cheap bike pump that stop you losing the air you pump in.
  • 6 years later...
Mines due again, Steering fluid is browning up.
Might see if i can get a blocker for the reservoir return this time.
At least my son is old enough to do the cranking job.
I was thinking it might be nice to add a T tap on the return to make future flushes easier. Anyone tried something like that? Probably too much hassle.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
